what is the BEST AFTERMARKET HIGH VOLTAGE ALTERNATOR???
Old Sep 28, 2008 | 05:16 PM
superhatchbackbros's Avatar
Default what is the BEST AFTERMARKET HIGH VOLTAGE ALTERNATOR???
as the title says, what is the best after market high OUTPUT alternator to fun in a ef?
Modified by superhatchbackbros at 9:44 PM 10/1/2008
Old Oct 1, 2008 | 08:44 PM
bump ttt anyone?
Old Oct 1, 2008 | 10:34 PM
mattison187's Avatar
try "excessive amperage" or "ohio generators" both are A+ high output alt. companys oh and BTW its high amperage not voltage.
Old Oct 3, 2008 | 07:26 PM
ANY1 ESLE???
Old Oct 4, 2008 | 07:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: (superhatchbackbros)
As mentioned... http://www.ohiogen.com/ it's what we use. 94
Old Oct 4, 2008 | 07:51 AM
Davus's Avatar
There's a lot of 160 amp Denso remanufactured alternators on the market. I'm using one, in fact, and it's been alright to me.
(My car, '96 Civic EX, has something like 70 stock)
Old Oct 4, 2008 | 04:26 PM
doggworld1233's Avatar
i use powermaster xs in my civic its a 170amp
Old Oct 5, 2008 | 07:31 PM
do u have any pictures of ur powermaster xs alternator? and is it reg finish or chrome? and whats the model number and how much? get back to me thanks.
Old Oct 5, 2008 | 11:31 PM
Default Re: (doggworld1233)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">i use powermaster xs in my civic its a 170amp</TD></TR></TABLE>
forgot about powermaster. i know alot of ppl who swear by um.
Old Nov 24, 2008 | 02:57 PM
starbai's Avatar
When upgrading to a higher amp alternator, does anything else have to be done? lower gauge wire? anything?
at my car's age and knowing that its never been changed and the abuse of my new stereo, I am trying to learn about alternators before my OEM one goes out.
Old Nov 24, 2008 | 04:44 PM
fcm's Avatar
fcm
Old Fart
Definitely upgrade the alt. charge line, I would also "beef up" the batt. to chassis to engine ground.94
Old Nov 24, 2008 | 05:43 PM
starbai's Avatar
ok not to be a total idiot but i'm going to need ya to break that down a little bit.
Beef up the battery I'm going to assume means get a better one? Like the optima batteries?
Alt charge line would be the wire going from the alternator to battery.
'to chasis and to engine ground' whats that mean?
.94 of any significance? whats that?
thanks
Old Nov 24, 2008 | 11:40 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
yes, yes, yes... your power, and grounding cables.
bigger battery..
alt charge line, the cable from the alt. back to the battery.
neg. battery post to chassis ground.
its great you want to upgrade your alternator, but how is all that current going to get through your tiny 70a alt. cable? its not designed for 160+amps of current, and will over time heat up that cable, and could break. let alone start a fire....
Old Nov 25, 2008 | 11:13 AM
twentyhurtz's Avatar
I've always heard ohio generators and Iraggi were the best, but i couldn't afford those so i went with a LoadBoss, it worked well, never had a problem and has lifetime warranty.
Old Nov 25, 2008 | 12:22 PM
95jdmej2's Avatar
Ohio generator, worth every penny
tim_r95
Jan 27, 2015 08:02 AM
j3wman
Nov 26, 2010 10:26 PM
contreras89
Honda Civic (2001 - 2005)
Jan 29, 2008 12:37 AM
Bulli Kid
Audio / Security / Video
Aug 10, 2007 05:04 PM
wishingiam
32
Feb 8, 2005 12:26 PM
