how to remove vin # from dash
Old Sep 28, 2008 | 12:49 PM
xileap2's Avatar
Default how to remove vin # from dash
I recently purchased a Si dash and need to remove the existing vin and put my CRX vin onto it. How would I go upon removing them with minor modification.
Old Sep 28, 2008 | 01:52 PM
dr_latino999's Avatar
Default Re: how to remove vin # from dash (xileap2)
Minus the illegalities of it - I don't even know if you are allowed to remove a vin without approval - isn't it a rivet?
Old Sep 28, 2008 | 01:57 PM
xileap2's Avatar
Default Re: how to remove vin # from dash (dr_latino999)
Yes, it has rivets, but there should be a way of removal without it being very noticeable...I broke my dash to get it out, just need a safe way of removing it from the Si dash.
Old Sep 28, 2008 | 02:08 PM
adeline's Avatar
I know here they say that you have to have highway patrol there to make it legal and you have to use rivets as close as possible to factory
Old Sep 28, 2008 | 02:59 PM
xileap2's Avatar
Default Re: how to remove vin # from dash (adeline)
That may be the case. So I'll probably head the the junk yard and take me extra vin # to find a way in taking it off. But then again the only reason cops look at your vin is when you get a parking tickets. I've gotten 3 traffic tickets on my s2k and no cop has looked at the vin.
Old Sep 28, 2008 | 03:40 PM
traxxasx's Avatar
Drill the rivet out with a small drill bit.
Then add new rivites.
Old Sep 28, 2008 | 04:14 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">I know here they say that you have to have highway patrol there to make it legal and you have to use rivets as close as possible to factory </TD></TR></TABLE>
Same here.
xileap2's Avatar
Default Re: (traxxasx)
That's what I had in mind, just wanted to be sure im the only one thinking that way
Old Sep 28, 2008 | 04:23 PM
Quartermile fanatic's Avatar
i wanted to do the same thing with my crx....i have an hf
Old Sep 28, 2008 | 05:17 PM
rbwdriven's Avatar
I've dont it multiple times, drilling rivets out and replacing dashes.
had cops pull me over etc.
you dont have to tell the man everything you do.
Old Sep 28, 2008 | 05:33 PM
SIred91's Avatar
Rainman
Default Re: (rbwdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">
You sure don't, but get caught and see how you get treated......
Old Sep 28, 2008 | 05:37 PM
wakaranai's Avatar
Default Re: (SIred91)
This is insanely sketchy.
Old Sep 28, 2008 | 05:42 PM
xileap2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">You sure don't, but get caught and see how you get treated......</TD></TR></TABLE>
It shouldn't be that bad, if I didn't get caught stripping out an s2k in my driveway, it should be difficult changing rivets.
Old Sep 28, 2008 | 05:56 PM
black0hatch's Avatar
Default Re: (xileap2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">Drill the rivet out with a small drill bit.
Then add new rivites.</TD></TR></TABLE>
yup thats all there is to it ive done it a few times too. and have been pulled over tons of times never a problem dont worry about it.
Old Sep 28, 2008 | 05:58 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">This is insanely sketchy. </TD></TR></TABLE>
Yeah because people never change out a blue/brown/maroon/broken dash for a black dash.
I personally drilled the rivets out with s small bit and used new rivets to swap dashes with the two EFs I owned at the same time.
I had my red EF get t-boned so when I bought a white DX I swapped dashes and VIN plates before I sold the t-boned red EF with it's "new" blue dash. I did so to kep the VIN numbers matching.
The same "sketchy" remarks can be made about "how to swap an engine at your house" if one thinks it will aid thieves in stripping a stolen car of its engine/
Old Sep 28, 2008 | 06:39 PM
Crx Jimmy's Avatar
Default Re: (B18C5-EH2)
use a 1/8 drill bit and drill the rivets out. Then use some new 1/8 rivets to re-install. It will look stock
Modified by Crx Jimmy at 10:45 PM 9/28/2008
Old Sep 28, 2008 | 11:01 PM
wakaranai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Sure. Ultimately, it is impossible to tell what is really going on. I agree that it is an arbitrary argument. Just the way I felt when I first saw the post and I didn't feel like contributing to this. Swapping vins and swapping engines is hardly the same thing. Done.
Old Sep 29, 2008 | 06:48 PM
OldSkoolDa91's Avatar
the only way i see swapping vin plates being sketchy is when you are trying to take vin plates from one car and put them into another. THAT is where you get into big trouble. that can be automatic jail time, at least where i live. like it was already stated, its not like people dont replace broken dashes or get rid of ugly colored dashes for black dashes every day. as long as every vin plate on the car matches, and is to that actual car, there is no problem at all. my friend has done 2 rhd conversion in hatches he's owned and put his vin plate on the jdm dash in the proper location, got pulled over once and had no problems at all.
btw, i'm getting ready to swap dashes in both my integra and my hatch for black dashes and will be swapping the vin plates from the old dashes to the new ones.
Old Sep 30, 2008 | 12:43 AM
wakaranai's Avatar
Default Re: (OldSkoolDa91)
Understandable. I used to be in the Bimmer scene (specifically E30's and 2002's) and swapping dashes was very common, due to most of them being cracked.
Old Oct 5, 2008 | 12:21 AM
wlee112's Avatar
hey sorry to crash your thread but does anyone know WHERE we can find these rivets that look similar to oem? esp since most hardware stores sell plain silver rivets. i need to rivet my vin too but the oem eg rivets are black... anyone know a place online i can find some similar rivets?
Old Oct 5, 2008 | 12:36 AM
RexShop's Avatar
Just use the silver ones and use a damn sharpie to color it... bam black rivets.
Old Oct 5, 2008 | 09:09 AM
crxcess's Avatar
Default Re: (RexShop)
I don't see any problem with swapping vin plates on the dash. its when you go to cut the vin off the firewall that will get you into trouble.
apm
Nov 17, 2005 10:19 AM
dxhatch93
Nov 16, 2005 11:58 PM
Monkey Fing a Coconut
Apr 6, 2004 03:24 AM
GotGSR
Mar 29, 2004 07:22 PM
GotGSR
Mar 29, 2004 02:30 PM
