throttle bodie synchronizing
i have fitted ninja 600 throttle bodies to my honda civic and now ive been told a will have to synchronise the throttle bodies to get them to run equal, how can this be done?
any info would be great thanks
i just did a quick google of "synchronise the throttle bodies" and it looks like theres loads of info out there. it seems you might need Vacuum Gauges.
i watched this: http://www.youtube.com/watch?v=UmLwyAPMBLI
i never realized this was required with FI, thought it was only with carbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsevenEm2 »</TD></TR><TR><TD CLASS="quote">LOL you dont sync throttle bodies, for they are electronic carburetors. The ecu tells them when to close/open via TPS.
err, if he is putting ITBs on a civic, he will need to sync them. all the throttle bodies need to open the same amount, just like carb butterflies do.
You can get them fairly close by setting them at full closed and working back from there, or get yourself a 4 post/cylinder vacuum gauge and set them, thats the most accurate way as said earlier.
Here is a link of a unit available from the uk.
http://www.carbtune.co.uk/c.com/carbdtls.html
Hope this helps.
Hope this helps.
RNbuilt
Honda Civic (2006 - 2015)
10
Dec 27, 2007 04:04 PM
