Question about a head swap
Old Sep 28, 2008 | 06:39 AM
MonsterRex's Avatar
Default Question about a head swap
There's a guy offering me a port and poliched d16 head. I have a d15. Can I just switch everything from one head to the next? Is there anything that I should replace while doing this swap?
Thnx in advanced
Old Sep 28, 2008 | 06:48 AM
sleepingciv's Avatar
Default Re: Question about a head swap (MonsterRex)
there is a big difference in the cam in hp from a d16 to a d15 is the d16 bare?? . everything will bolt up. i would change the cam seals and the valve seals
Old Sep 28, 2008 | 06:59 AM
89s1's Avatar
Default Re: Question about a head swap (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">there is a big difference in the cam in hp from a d16 to a d15 is the d16 bare?? . everything will bolt up. i would change the cam seals and the valve seals</TD></TR></TABLE>
Ignore that.
What KIND of d16 head is it? That makes more difference than anything.
If it is a non vtec sohc d16a6 head i would say buy it, if it is a non vtec d16y7 head i would say pass. (lack of cam selection)
If it is a d16 vtec head then its not exactly as "bolt on" as sleepingciv says it is. there are a fwe things you would need to change.
If it is a dohc d16 head than its not worth anything to you. Please give more info so that we can actually help you.
Old Sep 28, 2008 | 07:03 AM
Default Re: Question about a head swap (89s1)
you ask a basic question you get a basic answer
d16a6 d15b7
Old Sep 28, 2008 | 12:59 PM
MonsterRex's Avatar
It is a SOHC non-VTEC PM6 head from a 94 Civic, and yes it is bare. Freshly ported/polished. Will i actually see any substantial gains from this swap alone?
Old Sep 28, 2008 | 05:44 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonsterRex &raquo;</TD></TR><TR><TD CLASS="quote">It is a SOHC non-VTEC PM6 head from a 94 Civic, and yes it is bare. Freshly ported/polished. Will i actually see any substantial gains from this swap alone?
Depends on the rest of the mods, but I would say not likely anything substantial no.
BakedAlex
May 17, 2013 07:26 PM
bsmith100
10
Jun 12, 2008 08:36 PM
SpankyofNOLA
13
Dec 19, 2004 10:35 PM
Civichatch27
Sep 17, 2004 03:12 PM
whagkangmakulet
Oct 11, 2001 08:26 AM
