Rust in gas tank
Old Sep 27, 2008 | 10:53 PM
DevineCRX's Avatar
Default Rust in gas tank
I am trying to fix a downed F4 that hasnt been run in a few years. When I was draining the old gas, I noticed that the tank has rust inside of it. Does anyone know how I can flush the tank and remove the rust? I read about a product called KREEM. Does anyone have any experience with KREEM?
Old Sep 28, 2008 | 09:15 AM
CivicWagonRUS's Avatar
I've used KREEM before, I bought the whole kit but only used the first 2 bottles, but not the final white goop step. My gas tank turned out great, not a spot of rust in there now.
Old Sep 28, 2008 | 10:56 AM
DevineCRX's Avatar
Default Re: (CivicWagonRUS)
Thanks, I will give it a try. Any tips on using KREEM?
Old Sep 28, 2008 | 12:20 PM
Default Re: (DevineCRX)
Just follow the directions that are included, and if I were you, I'd skip the actual 'KREEM' step where you coat the inside with the white goo.
Old Sep 29, 2008 | 12:26 PM
DevineCRX's Avatar
Did you do the step where you add a peice of chain or nuts into the tank to clean out the rust? Why do u suggest not using the actual coating? Thanks
Old Sep 30, 2008 | 02:02 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Rust in gas tank (DevineCRX)
I read about a clever method of removing tank rust from someone on svrider. I've never tried it though.
To remove the rust, do this:
Get your battery charger. 2amp, .75amp, doesn't matter.
Drain your tank. Remove the petcock. Seal off petcock hole. Fill with water.
Add a tablespoon of WASHING SODA, not baking soda. You can find it at the grocery store.
Hang a section of bare wire into the water. MAKE SURE IT ISN'T TOUCHING THE TANK.
Attach the + side of your charger to this wire.
Attach the - side of your charger to the tank.
Electrolysis will remove the rust from the tank and deposit it on the wire in the water.
You may need to remove the wire and wipe the crud off it periodically.
The 2amp charger will do it in a couple of hours, the .75amp in a couple of days.
Best part is, unlike acid etching, it will not remove any 'good' metal.
madblkscientist
Aug 10, 2009 10:29 AM
jdm inc
Oct 30, 2008 07:14 PM
prelude_93vtec
Dec 21, 2007 08:29 AM
JohnBlaze
Honda Motorcycles
Sep 14, 2003 12:54 PM
civicracer1993
Jul 7, 2002 08:11 AM
