honda connectors and pins
Old Sep 27, 2008 | 06:33 PM
tony413's Avatar
Default honda connectors and pins
i was searchin the web and came across some sites and wanted to know if had find places that sell the OEM style wire harness connectors.
I found a few sites that look close to what we have but i just wanted to see if there was any place else for sure, because honda doesn't.
also im interested in this because i want to make a new harness without cuting the existing one. even if i could just buy stock pins for the stock connectors that would be of great help.
i checked waytek but didnt find anything close to stock
http://fdj.en.alibaba.com/grou....html
http://foisontpe.trustpass.ali....html
http://connectors-catalog.sys.....html
EDIT: i found a place to buy STOCK honda style fuel injector connectors. ill update this as i found other sensor connectors.
the molex MX150L connector looks like the dead plug found on the drivers side engine bay, that is used to wire up a resistor box
Modified by tony413 at 11:05 PM 9/27/2008
Modified by tony413 at 11:10 PM 9/27/2008
Old Jan 30, 2010 | 06:41 PM
CORE132's Avatar
Default Re: honda connectors and pins
can u pm the info on where to buy honda connectors and pins. i wanna make a new harness since my engine harness for my ob0 are broken n my wires are messed up
Old Jan 31, 2010 | 06:54 AM
xzodiackillerx's Avatar
http://www.tycoelectronics.com/catal...ML=10576,17560
keep looking on this site I found it once but didn't bookmark it so this should help.. and after you find the right part number you have to find a place that will sell less than 4,000 pieces
I have some OBD1 ECU pins and connectors if you are looking for them.. IDK if the pins will fit the OBD0 ECU...
I am looking for the sensor side pins and connectors
Charlie Moua
Dec 4, 2010 11:47 AM
CORE132
Jul 6, 2010 03:09 PM
cehcivic15
Dec 19, 2008 10:26 AM
miksew
Audio / Security / Video
Aug 4, 2006 02:57 PM
bacid
Jul 26, 2001 09:49 AM
