Help! Need opinions. Cut harness!!!
Old Sep 27, 2008 | 05:36 PM
Bangher4$'s Avatar
Default Help! Need opinions. Cut harness!!!
Hello, someone stole the computer out of my 2000 ls. The [pejorative]ss cut the computer out instead of unpluging it.
Whats the best way to fix?
Splice wires to new plugs?
Pull harness?
Opinions please
thanks
Old Sep 27, 2008 | 05:38 PM
ZygSpeed's Avatar
Default Re: Help! Need opinions. Cut harness!!! (Bangher4$)
Superglue?
Sorry, couldn't resist.
You've pretty much named the options.
Good luck.
Old Sep 28, 2008 | 07:00 AM
THC07's Avatar
I would think splicing it would be easier.
Im not sure how much of the harness you would have to remove, maybe someone else can say.
Old Sep 28, 2008 | 09:21 AM
lsvtecturbosol's Avatar
Default Re: Help! Need opinions. Cut harness!!! (THC07)
In order to fix that issue the right way you would have to remover every inch of wire from the car. ALl the way from the headlights to the taillights and it's a pain. Also finding a full wire harness would be hard and expensive. Your easiest fix would be to cut and splice the new harness in and it should be perfectly fine.
Old Sep 29, 2008 | 11:41 AM
sheekdude's Avatar
Default Re: Help! Need opinions. Cut harness!!! (lsvtecturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecturbosol &raquo;</TD></TR><TR><TD CLASS="quote">In order to fix that issue the right way you would have to remover every inch of wire from the car. ALl the way from the headlights to the taillights and it's a pain. Also finding a full wire harness would be hard and expensive. Your easiest fix would be to cut and splice the new harness in and it should be perfectly fine. </TD></TR></TABLE>
X2. Thats what i did on my itr... ecu harness was cut...
Old Sep 30, 2008 | 05:50 AM
Bangher4$'s Avatar
Default Re: Help! Need opinions. Cut harness!!! (sheekdude)
this is a LS 2000. is it obd2a or b? it has an immoblizer. which computer can i buy? does it have to be a 2000 computer? what if i lost my key as well?
can i buy any key, and get it flashed to any computer i buy?
Old Sep 30, 2008 | 06:08 PM
mynameissangg's Avatar
super glue
Old Oct 1, 2008 | 08:00 AM
Bangher4$'s Avatar
Default Re: Help! Need opinions. Cut harness!!! (mynameissangg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mynameissangg &raquo;</TD></TR><TR><TD CLASS="quote">super glue</TD></TR></TABLE>
Update: New plan, instead of useing a obd2 00-01 computer with that immo crap, why cant i just use a obd2a ecu and splice in obd2a plugs instead. will the wire colors be the same so i can still color match when splicing?
Pros Cons?
Thanks
soNNy638
Audio / Security / Video
Mar 28, 2010 06:55 AM
tyler100
14
Nov 5, 2008 02:56 PM
MattsGreenEG
Nov 29, 2007 11:19 AM
SLO Sol
Dec 30, 2005 10:44 AM
