H22 Accord Coupe Build Thread, This time i'm doing it right!!
Well, I've been driving this accord for over 3 years now and in the meantime
I've done quite a bit to it as far as appearance, JDM parts, H22, Suspension, etc.
Here's what it has looked like in the past:
And here is pretty much how it sits now :
So i was converting from an auto to manual tensioner on the H22 recently and
I ran into a few issues so i decided i needed to pull the motor out to fix it.
I then decided that since i was pulling the motor out i may as well tackle a few more
projects while i have the motor out and see how it goes.
I'm hoping to do the following :
Auto to manual tensioner, Water pump, Timing Belt, Head studs, all new gaskets,
New clutch, and a WIRE TUCK
So here goes, this is what i'm working with, I will update the pics everyday!
Quite a wiring Mess I'd say
Here's her heart
Modified by jdmcd7_cali-luv at 12:23 AM 10/1/2008
Here's her heart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">that rear decklid looks sick (even though you said it doesnt look like that anymore)</TD></TR></TABLE>
Here it is now, let me know what you think. I'm still not sure about it
i like the new deck..it looks perfect and non half-assed
but damn i hope i get stationed in Cali next year, yall go hard over there.
how far are you going with the wire tuck? even a slight one definitely cleans up the bay quite a bit. good luck on the whole project as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">i like the new deck..it looks perfect and non half-assed
Thanks, I appreciate it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andryzzle »</TD></TR><TR><TD CLASS="quote">how far are you going with the wire tuck? even a slight one definitely cleans up the bay quite a bit. good luck on the whole project as well.</TD></TR></TABLE>
Still not sure, i'd like to go pretty far with it, i guess it depends on how long the motor will be out the car
love the rear deck. shyts awsome. i still need to order some diffrent fabric for my car. as people are hatin on the pandas. and somone accidently tore the rear off. was it easy to take the rear deck out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcd7_cali-luv »</TD></TR><TR><TD CLASS="quote">
oh shnaps peep the panda in the back. thats why i like to see.
</TD></TR></TABLE>oh shnaps peep the panda in the back. thats why i like to see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huskyl3oi »</TD></TR><TR><TD CLASS="quote">love the rear deck. shyts awsome. i still need to order some diffrent fabric for my car. as people are hatin on the pandas. and somone accidently tore the rear off. was it easy to take the rear deck out?</TD></TR></TABLE>
Yeah the rear deck comes out pretty easily.
just unscrew the 2 10mm boltsthat hold the 3rd brake light on,
take out the bulb and remove the brake light.
then the deck will come off, its held on by a few clips, they just pop off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joezjdm4dr »</TD></TR><TR><TD CLASS="quote"> JG motor...thats sick....ferio EG squad member #55</TD></TR></TABLE>
Thanks man... ferio's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD5SiRHero »</TD></TR><TR><TD CLASS="quote">Keep it up homie....CD Accords all day every day </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">nice cali. looks like good work. interested to see the final product too.
Thanks
The other day I got that bolt extracted that broke off inside the block.
I also fixed the threads for the water pump bolts and got that installed.
I've just been working on some wiring now,
and I'm gonna deep clean the engne bay later today
</TD></TR></TABLE>Thanks
Got the bolt out that was the whole reason I pulled the motor
Also re-threaded the water pump bolts that were stripped
Cleaned up the bay as much as i could with degreaser
Before:
After :
Still got some more cleaning to do before I'm done
Cali-Luv all Day
Before:
After :
Cali-Luv all Day
Since you have the motor out I would suggest doing any preventative maintenance that you have not done i.e. timing belt, oil pump, etc. Also Paint the bay. It is the perfect time and it will look so much better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- »</TD></TR><TR><TD CLASS="quote">Also Paint the bay. It is the perfect time and it will look so much better.</TD></TR></TABLE>
might as well. i kicked myself for a while for not doing it when i had mine out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- »</TD></TR><TR><TD CLASS="quote">Since you have the motor out I would suggest doing any preventative maintenance that you have not done i.e. timing belt, oil pump, etc. Also Paint the bay. It is the perfect time and it will look so much better.</TD></TR></TABLE>
I have a new water pump and timing belt already. I alo purchased a complete gasket kit and will be replacing all of those soon.
As for the painting, I really wanna do that, I've been thinking about it a lot.
