car studers when reving up
Old Sep 27, 2008 | 09:48 AM
laszlo's Avatar
Default car studers when reving up
car is a 89 civic wagon has a d15. car starts to stuter when you are going throw the gears.like it feels like it is backing up.then the power kicks in.any help would be good thanks
Old Sep 27, 2008 | 11:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
Check your ignition timing.
Is your check engine light on? Have you done a tune-up recently?
Old Sep 27, 2008 | 11:58 AM
Nutnwrench's Avatar
Default Re: car studers when reving up (laszlo)
are you sure its not just misfiring under load? check your plugs and wires or if its been quite awhile just go ahead and do a tune up on your hot rod.
Old Sep 27, 2008 | 01:44 PM
laszlo's Avatar
yah ceck light fore code 4.thats for o2 and heat senser. but i took it to the shop they check the wires,plugs and they changed the disturbater cap and cleard the code and now it runs shity.
but i have know started ajusting the timing and it is runing better
Old Sep 27, 2008 | 01:46 PM
sleepingciv's Avatar
you timing belt is prob old and worn out
Old Oct 6, 2008 | 11:46 AM
Nutnwrench's Avatar
Default Re: car studers when reving up (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">you timing belt is prob old and worn out </TD></TR></TABLE> think about that for a sec then try again
90civic-ZC
Nov 21, 2011 06:45 PM
benji7288
Mar 19, 2009 04:48 PM
Civicta
Jul 21, 2008 06:30 PM
PAsol_er
May 23, 2005 05:05 PM
Deathwish
May 9, 2005 09:45 PM
