1991 integra DA weather issues?
Old Sep 27, 2008 | 08:19 AM
Auby's Avatar
Default 1991 integra DA weather issues?
My mom is having car problems and I was seeing if anybody would be able to help out.
My mom has a 1991 Integra DA when it is running down the highway it dies. When it is hot outside it won't start. It eventually starts but it may take several hours before it starts. She can spray starting fluid into the breather and it will start but it doesn't always keep running. She has changed out the spark plugs, rotor, distributer cap, coil, ICM, tested the fuel pump and it's okay, relay mod is fine, and changed out the fuel filter.
Thanks
Old Sep 27, 2008 | 08:46 AM
mr.beeks's Avatar
Default Re: 1991 integra DA weather issues? (Auby)
your mom does all this???
just check the cables inside distributor connecting to the igniter they might be corroded so best bet is to buy a new distributor.. and check plugs also...
Old Sep 27, 2008 | 09:10 AM
EdoMoto's Avatar
Replace the Fuel Pump Relay. Its Broen in color and under the dash. Drivers side.
Edo
Old Sep 28, 2008 | 10:06 PM
Auby's Avatar
Thanks. I will let her know all that has been said here so she can give it a whirl. If these dont work I will be back with more questions. Again Thanks.
Old Sep 29, 2008 | 09:57 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (Auby)
mom mechanic ftw
Old Oct 1, 2008 | 11:53 AM
Auby's Avatar
Default Re: 1991 integra DA weather issues? (mr.beeks)
After taking out the fuel pump and testing it she found that she is not getting power to the fuel pump.
Old Oct 1, 2008 | 12:13 PM
blakkvtec's Avatar
Replace the Fuel Pump Relay... Tons of old Ef's/DA's have that problem. Mine did. Put the new relay in and its been fine.
Waldron Racing
Nov 26, 2013 06:45 AM
steven83r
Oct 21, 2013 07:21 AM
Coltmorris
Sep 11, 2009 12:51 PM
marcosenid
Oct 30, 2008 04:52 PM
civic89si666
Mar 20, 2006 04:54 PM
