Need Advice On Build
Old Sep 27, 2008 | 05:49 AM
hiphop23j's Avatar
Default Need Advice On Build
i have a 98 itr head and stock b18c5 block
head has
port & polish manifold
ferrea valves
3 angle valve job
supertech valve springs with itr retainers
crane stage 2 cames
i want advice on build set up on block and head willing to redo everything,
i want at LEAST 205hp and its daily driven , help out guys thanks.
Old Sep 27, 2008 | 06:05 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Need Advice On Build (hiphop23j)
You will need a very good header.
Old Sep 27, 2008 | 06:35 AM
hiphop23j's Avatar
Default Re: Need Advice On Build (mar778c)
i have some 4-1 headers i forgot the name though, i also have some golden eagle rods and 11 compression itr pistons, but ther 1mm bigger so i would have to bore out 1 over is it worth it, wat else can i do to the head and block.
Old Sep 27, 2008 | 09:55 AM
racebum's Avatar
everything you have is great. i'd just find out what compression those cams work with the best, make sure you have it and get a great header. that combo you posted above should be able to make 200whp{least i would think so} if you get everything dialed. what do you wanna change anything for? that's a good DD combo.
Old Sep 27, 2008 | 12:34 PM
hiphop23j's Avatar
Default Re: Need Advice On Build (idrivesideways)
is it worth it to bore the block out to 82mm or just sleeve it and go 84 mm its gona be daily driver/ lil race here n ther, would it be reliable.
Old Sep 27, 2008 | 01:26 PM
racebum's Avatar
cost, cost, cost, only you can answer that one
Old Sep 27, 2008 | 01:43 PM
PyroProblem's Avatar
82mm is good, 84mm is better...
Old Sep 27, 2008 | 03:07 PM
hiphop23j's Avatar
Default Re: Need Advice On Build (PyroProblem)
can i go 82mm in the b18c5 with out any problems, just mostly daily 11 compression and lil race here and be reliable.
Old Sep 27, 2008 | 03:11 PM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">You will need a very good header.</TD></TR></TABLE>
tuner and ecu program too
Old Sep 27, 2008 | 05:08 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hiphop23j &raquo;</TD></TR><TR><TD CLASS="quote">can i go 82mm in the b18c5 with out any problems, just mostly daily 11 compression and lil race here and be reliable.</TD></TR></TABLE>
I don't think it would be justifiable to tear into the block. I would direct my attention to a better header and a good intake. A recent customer of mine made 206 on a dynojet with a stock-blocked M22x C5.
Old Sep 27, 2008 | 07:16 PM
Sixfortyfive's Avatar
Default Re: Need Advice On Build (clean rice)
u can get 200 on a gsr with a stock block so, what i would suggest for u is to just build ur itr head more
Old Sep 28, 2008 | 08:18 AM
hiphop23j's Avatar
yeah i was thinking that to about the stock block, since i got the eagle rods im gonna leave the bore like that and get pistons
whats the bes ecu for this setup i have a chipped p28 with crome but i was gona upgrade
wat else should i do to the head?
wat piston to get and compression for wat im lookin for?
Old Sep 28, 2008 | 08:45 AM
tune on hondata, hytech headers?
Old Sep 28, 2008 | 09:59 AM
hiphop23j's Avatar
Default Re: Need Advice On Build (Sixfortyfive)
anything else for the head, thanks for the help
96ls_vtec_teg
Jan 27, 2008 07:28 PM
cltitus
Jun 7, 2006 09:30 AM
tuanhoprosk8
14
Aug 22, 2005 09:22 AM
The G2 Racer
17
Mar 29, 2005 08:10 PM
_noname_
Jul 9, 2004 03:27 AM
