what welder for 16gauge mild steel?
Old Jul 26, 2002 | 05:13 PM
true's Avatar
Default what welder for 16gauge mild steel?
What welder do you fabrication guys use? I'm gonna be welding some mild steel pipes.....is something like the wire feed from home depot ok ($339)....or is that weld kit a piece of junk?
Old Jul 26, 2002 | 06:05 PM
Flamenco-T's Avatar
Default Re: what welder for 16gauge mild steel? (true)
I used wire feed to weld in JDM front end and a couple of piping, 16 gauge...but I am still learning to make weld beads, I have been practicing spot welds, the wire feed works great...for spot welds...
stan
Old Jul 26, 2002 | 06:33 PM
BigMoose's Avatar
If you want it pretty, TIG (Tungsten Inert Gas) with a high nickel (stainless steel) filler rod. I use 100% argon cover gas.
Regards,
BigMoose
Old Jul 26, 2002 | 11:09 PM
LsTurbo91's Avatar
stay away from gasless flux cored mig welders please.
Old Jul 26, 2002 | 11:50 PM
boostaholic's Avatar
Default Re: what welder for 16gauge mild steel? (LsTurbo91)
My welder uses a 130amp Miller wire feed MIG welder with argon gas cover. When you're welding, tac your pipes together first then go over it evenly with the MIG gun. Definitely use gas, the welds will be much more even and prettier.
Old Jul 30, 2002 | 08:04 AM
Full-Race Javier's Avatar
Default Re: what welder for 16gauge mild steel? (BigMoose)
tig is purty
Old Jul 30, 2002 | 08:53 AM
RGAZ's Avatar
New User
Default Re: what welder for 16gauge mild steel? (javierb14)
Arc=ugly junk
gas-less MIG=still ugly
Argon MIG=good
TIG=great
TIG w/ good filler=professional
I use argon/CO2 covered MIG with 0.30 wire. It works very well on 16ga steel but takes some practice to get the feed speed and voltage set right. It is the all purpose welder IMO.
Randy
Bjorn
Welding / Fabrication
Apr 14, 2009 08:26 AM
postman
16
May 20, 2008 10:08 PM
akira712
17
Apr 2, 2007 12:32 AM
redsikiller
Apr 29, 2006 12:04 PM
Luserkid
May 27, 2005 04:29 PM
