where can i get hid bulbs for pretty cheap for my dc5
Be carful tho. I just installed some yesterday on an 04 RSX and it was quite a bit of work. The bulbs that you get when you order an H1 hID kit do not just plug right into the headlight housing. the way it works on the RSX is that the harness needs to be plugged into the rear side of the adapter and the bulb is connected in the front and the whole adapter is plugged into the housing. and all you get with the HID plug and play kits is just the bulbs ballasts and wiring and mounthing things. So keep in mind some customization needs to be done.
Civiclx
Feb 19, 2008 10:05 PM
EGPrelude
Jun 27, 2007 06:54 PM
