gs-r all motor setup
b18c1 motor
rebuilt bottom end:
-82mm ITR pistons
rebuilt head:
-valve job
-aftermarket valve springs and retainers
bolt on parts:
-JG Edelbrock 4-2-1 header
-2.5 in test pipe
-AEM cold air intake
-310cc injectors
-B&M fuel pressure regulator
-p28 w/mugen program
what kind of horsepower gains can i expect with this kind of setup?
better yet what kind of times should i expect to pull in the quarter on street tires?
rebuilt bottom end:
-82mm ITR pistons
rebuilt head:
-valve job
bolt on parts:
-2.5 in test pipe
-310cc injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97geeser »</TD></TR><TR><TD CLASS="quote">b18c1 motor
rebuilt bottom end:
-82mm ITR pistons
rebuilt head:
-valve job
bolt on parts:
-2.5 in test pipe
-310cc injectors
I don't see any cams listed, what's the point of stiffer springs w/o aftermarket cams? And ditch that mugen programed ecu. Or at least get a real tune on that P28.
In the end, you will be close to ITR numbers, and should be more with aftermarket cams.
hold on now....he wasn't finished reading yet. The information at the top of this forum is taking him a while to get through...
https://honda-tech.com/zerothread/1583606
darrinbrewer
Jul 6, 2004 02:38 PM
