12:1 compression p73 pistons
Old Sep 26, 2008 | 02:01 PM
onoitsaldrin's Avatar
Default 12:1 compression p73 pistons
hey guys im a noob at tunning hondas just wondering im doing an all motor build with my b18c1 block with a b16b head
im using nippong racing p73 piston 81.5
with ctr cams
skunk2 intake
jvt headers
what im wondering what size of injectors should i use as of right now i have some denso 280cc injectors someone told me that i need to be using some 400cc injectors... and what kind of gas should i be using some 93? maybe well thanks a bunch
Old Sep 26, 2008 | 02:14 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 12:1 compression p73 pistons (onoitsaldrin)
whatever your tuner/engine builder/dyno tells you you need is what I'd go with.
Old Sep 26, 2008 | 03:38 PM
Default Re: 12:1 compression p73 pistons (00Red_SiR)
is it better if i use a vafc2 or a hondata s200
Old Sep 26, 2008 | 04:25 PM
00Red_SiR's Avatar
All Motor Mentor
I'll put it to you like this... That's the same as asking, "is it better to use a calculator or a computer?". Apples and oranges. Your tuner/engine builder will be able to guide you.
Old Sep 26, 2008 | 05:17 PM
lol i know what your saying but can i get an advice maybe cause im the one doing the building
Old Sep 26, 2008 | 08:50 PM
will it be streetable use
Old Sep 27, 2008 | 03:23 PM
1990_integra_DA9's Avatar
go with hondata, From experience never go with a vafc they suck. I have s300 it works amazing plus you can use your own computer to do diagnositic like ses lights and adjust everything on your own if need be.
Old Sep 29, 2008 | 08:28 AM
Default Re: 12:1 compression p73 pistons (1990_integra_DA9)
finallyy something helpful
Old Sep 29, 2008 | 08:29 AM
ty
Old Sep 29, 2008 | 08:42 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 &raquo;</TD></TR><TR><TD CLASS="quote">go with hondata, From experience never go with a vafc they suck. I have s300 it works amazing plus you can use your own computer to do diagnositic like ses lights and adjust everything on your own if need be.</TD></TR></TABLE>
S300 with a 2 step...even better
Old Sep 29, 2008 | 08:45 AM
GoldLudeRay's Avatar
what kinda of gas are you running in this build that has a lot to do with inj size!!!
Old Sep 29, 2008 | 10:56 AM
racebum's Avatar
Default Re: (GoldLudeRay)
what the tuner wants to use is the proper answer. however, stock injectors should be fine at higher pressure. your cams are a little small for 12:1 compression but i don't see larger injectors being needed on an engine that is going to produce that power level. if you have 280s@45psi {guessing} that's a little larger than stock and would help keep the duty cycle down. normally you don't need to step up injector size unless you start running near 100% duty cycle.
Old Sep 29, 2008 | 11:15 AM
Default Re: (idrivesideways)
dude you are awesome thank you very much dropping in the engine on friday hehehehe cant wait
Old Oct 5, 2008 | 06:46 AM
P12 EG6's Avatar
Default Re: (onoitsaldrin)
no , u should get bigger than stock injectors, so you can run them at lower duty cycle, and you won't have to worry about them maxing out then ur motor running lean, as for ecu hondata s300 its so easy to work with, well worth the money!
b20vtech
Mar 9, 2006 06:24 PM
xonefastackx
Jun 12, 2005 09:17 AM
singlecamkilla
13
Nov 5, 2004 06:04 PM
Acoupdetat
13
Oct 22, 2004 10:33 AM
GapxGuy
16
Apr 21, 2004 11:33 AM
