Oil/grease burning off exhaust after engine swap
Old Sep 26, 2008 | 01:42 PM
kalm_traveler's Avatar
Default Oil/grease burning off exhaust after engine swap
Ok, so I replaced the engine in this 4dr, but ever since there has been this mysterious smoke coming up from below the motor or something.
There are no drips, and I can't see anything thats wet (oil, coolant, and trans fluid haven't gone down at all).
Now, I know that it can take a little bit for stuff to burn off the exhaust manifold but how long should it really take? This car has probably idled or been driven lightly around the neighborhood for 30-45 mins so far and it's still coming out.
The only other thought I had was maybe exhaust is leaking from either inbetween the downpipe and that little mini piece, or the mini piece and the catalyst?
It's greyish in color, not white like antifreeze or blue like oil.
The car has not been driven on normal roads or the freeway at all, if that makes a difference.
Old Sep 26, 2008 | 07:39 PM
dacrxguy's Avatar
Default Re: Oil/grease burning off exhaust after engine swap (kalm_traveler)
some ones greasy hands got all over the block and exhaust itll go away might take a while depending on how much grease got on
Old Sep 26, 2008 | 08:53 PM
Pooby88's Avatar
Default Re: Oil/grease burning off exhaust after engine swap (dacrxguy)
Spray it off with brake clean or carb clean. Or take it to a coin-op car wash and hose it off. There may be a couple globs of grease that may smoke and smell for a day or two.
Old Sep 27, 2008 | 10:01 AM
Default Re: Oil/grease burning off exhaust after engine swap (Pooby88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooby88 &raquo;</TD></TR><TR><TD CLASS="quote">Spray it off with brake clean or carb clean. Or take it to a coin-op car wash and hose it off. There may be a couple globs of grease that may smoke and smell for a day or two.</TD></TR></TABLE>
ooh good ideas! thanks man, I will spray around there with brake cleaner, then hose it off and see if it help.
Thanks again
Old Sep 27, 2008 | 01:07 PM
IndySporty's Avatar
Whenever I do an engine swap I always tell customers it could smoke lightly for the first 3-5 days. Grease gets in wierd places when you change an engine.
MHaz1701
Jan 25, 2018 07:39 PM
vodkaTM
Dec 7, 2009 01:28 PM
kalm_traveler
Aug 31, 2008 02:10 PM
Sprockets
Oct 7, 2003 08:39 AM
thashadow
May 14, 2002 04:05 PM
