Parents SNAFUd my car!!! Someone Please Help!!!
Hey Guys,
I am a rat at VMI and I am not allowed to have my car here, so I left it at home with my parents. So my mom left the lights on my 90 CRX si on the other day and someone tried to help her jump it and crossed the cables. It blew a fuse, so she called AAA and they towed it home and replaced the fuse. My dad jumped the car and said a check engine code was thrown. He does not know how to read the codes, but I have it set up so he can flip a switch and the check engine light flashes the code.
Anyone know what it might be that happened off-hand? A friend of mine is going to check it out for me, but I dunno when my dad is going to let him come over.
PLEASE HELP ME OUT
Thanks in advance,
Brian
PLEASE HELP ME OUT
Thanks in advance,
Brian
Does it run? does it run correct? Hard to really say what fuse did it blow the main under the hood?
This might help here is the error codes Num: Code: Possiable Cause: Location:
0 Ecu Faulty or shorted, Check engine light does not appear when starting Passenger side foot well
1 Primary O2 Sensor "A" (O2) Open or Short in O2 sensor circuit, bad O2 sensor - More Exhaust Manifold
2 O2 Sensor "B" (O2) Open or Short in O2 sensor circuit, bad O2 sensor Cat. Converter
3 MAP Sensor (MAP) Loose or dirty connection, Short or open in circuit, Cracked or loose vacuum line, Bad sensor - More Firewall or Throttle Body
4 Crank Angle Sensor Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
5 MAP Sensor (MAP) Mechanical problem, Disconnected piping - More Firewall or Throttle Body
6 Coolant Temperature (TA) Loose or dirty connection, Short or open in circuit, Bad sensor - More Head, under distributor
7 Throttle Angle (TPS) Loose or dirty connection, Short or open in circuit, Bad sensor - More Throttle Body
8 Top Dead Center (TDC) Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
9 No. 1 Cylinder Position (only on 1.6L) Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
10 Intake Air Temperature (IAT) Loose or dirty connection, Short or open in circuit, Bad sensor - More Intake Manifold
11 Does not appear to exist
12 Exhaust Gas Recirculation System (EGR) Loose or dirty connection, Short or open in circuit, Cracked or loose vacuum line, Bad sensor - More Firewall right hand side
13 Atmosphric Pressure (PA) Loose or dirty connection, Short or open in circuit, Bad sensor - More Inside car passenger side wall
14 Electronic Air Control (EACV or IAC) Loose or dirty connection, Short or open in circuit, Dirty, Bad sensor - More Throttle Body
15 Ignition Output Signal Loose or dirty connection, Short or open in circuit - More Distributor
16 Fuel Injector Loose or dirty connection, Short or open in circuit, Bad injector, Resistor Box - More Fuel rail, Right side close to firewall
17 Vehicle Speed Sensor (VSS) Loose or dirty connection, Short or open in circuit, Bad sensor - More Left front tire, Transmission
18 Does not appear to exist
19 Lock Up Control Solenoid (auto trans only) - Loose or dirty connection, Short or open in circuit, Bad sensor - More Loose or dirty connection, Short or open in circuit, Defective soleniod valve
20 Electric Load Detector (ELD) Loose or dirty connection, Short or open in circuit, Bad sensor - More Right side shock tower, Built into the Main Fuse Box
good luck -ImmortalCRXSIR
My dad said it ran, and I got sent him a write up on how to read the codes. He said it is flashing a code nine (his words were nine flashes, pause, nine flashes, pause, and so on...) So I am looking at the distributor going bad then?
Modified by DEPintheCurve at 9:44 AM 9/27/2008
I've seen people do that and completely blow a coil so that could be the problem but you said it starts so thats definatly not it. tell him how to clear the code and drive the car around the block if possible and see if the code goes back on.
flat-blk-HB
10
Dec 12, 2020 12:13 AM
crxaddikt
10
Sep 13, 2014 11:47 AM
shabasoft
Aug 26, 2004 06:32 AM
