91 h22a accord idle problem
Old Sep 26, 2008 | 07:29 AM
jsmeal04's Avatar
Default 91 h22a accord idle problem
I am having problems with my h22a swapped accord it would surge three or four times to about 3000 RPM then would just idle at 3500 RPM then I removed a VAFC and a turbo kit I had on it and know it will only stay running if you feather the throttle can anybody shed some light on the situation thanks
Old Sep 26, 2008 | 09:46 AM
turboH22Aakkord's Avatar
Default Re: 91 h22a accord idle problem (jsmeal04)
I was thinking some sort of vac leak...check you vacume lines and if you just took off a turbo setup did you change the injectors? you may have effed up one of the injector seals creating a huge vac leak haha. just my .02... good luck
Old Sep 30, 2008 | 09:05 AM
jsmeal04's Avatar
Default Re: 91 h22a accord idle problem (turboH22Aakkord)
i go over the lines again and make sure but i never changed the injectors when i boosted it but i also went from a MSD blaster 2 coil back to a stock internal coil would that cause firing problems with NGK iridium IX plugs? thanks for your help
Wolfmonkey
Mar 1, 2018 08:17 PM
h22vtec337
Sep 15, 2013 06:26 PM
95jdm h22a accord
Jul 1, 2008 10:49 AM
auto-e-shop.com
Jul 26, 2005 04:13 PM
Subwarrior
Jan 5, 2005 06:57 PM
