Benefits of JDM Type-R Cams in a 99 Si B16A2????
Old Sep 26, 2008 | 07:15 AM
1SloNeon's Avatar
Default Benefits of JDM Type-R Cams in a 99 Si B16A2????
Hey guys,
Wondering what real benefits i will gain from putting 97 spec JDM Type-R Cams with Dual Valve Springs/retainers and a Ported Type R intake manifold in my B16A2??? My 99 Si is basicly stock with just intake/header/exhaust and is my daily driver. My friend is selling cams/valvesprings/intake manifold and will give me a good deal on them. All input is greatly appreciated. Thanks!!
Old Sep 26, 2008 | 08:10 AM
b20beast83's Avatar
Default Re: Benefits of JDM Type-R Cams in a 99 Si B16A2???? (1SloNeon)
Install the cams and valve train.
Old Sep 26, 2008 | 10:32 AM
1SloNeon's Avatar
Default Re: Benefits of JDM Type-R Cams in a 99 Si B16A2???? (b20beast83)
Ok but what gains and advantages will i see from it????
Old Sep 26, 2008 | 10:36 AM
robfrmny21's Avatar
you will gain mid range tq and hp through out the revs seeing the cams have a higher lift and duration
use the itr springs cuz you could drop a valve on the exhaust side seeing it has single springs
Old Sep 26, 2008 | 11:09 AM
1SloNeon's Avatar
Default Re: (robfrmny21)
Ok thanks man. Yea he is selling ITR dual valve springs and retainers as well with the cams. Hes also throwing in a ported intake manifold although i believe the oem itr manifold is ported stock.
Old Sep 26, 2008 | 11:51 AM
b20beast83's Avatar
Default Re: (1SloNeon)
i would leave on the stock manifold and sell his ITR
Old Sep 26, 2008 | 12:07 PM
solattack77's Avatar
Default Re: (b20beast83)
def. keep the b16 mani
Old Sep 26, 2008 | 12:29 PM
1SloNeon's Avatar
Default Re: (solattack77)
Y should i keep the stock b16 manifold??? the type r one is ported out???? Please explain....thanks!!!
Old Sep 26, 2008 | 01:40 PM
eg6style's Avatar
Putting on the type r mani gives you high end but you will lose your low end. Basically you want to keep your low and mid range on you car. Unless you just want topend then you can put the the type r mani and lose torque. Its up to you. I just kept my stock b16 mani and port matched it with a type R tb. My car was faster than my friends b16 with ctr cams,skunk2 mani, and type r tb. Mine was b16 with ctr cams, stock mani ported matched with a type r tb. Both cars were hatches.
Old Sep 27, 2008 | 04:35 AM
1SloNeon's Avatar
Default Re: (eg6style)
oooo ok gotcha, looks like ill just get the valvetrain from him then. Thanks for the info!!
Old Nov 12, 2008 | 07:31 PM
lee0149's Avatar
hey by the way did you use the dual value springs? would it be bad if you dont?
Old Nov 13, 2008 | 04:42 AM
1SloNeon's Avatar
Default Re: (lee0149)
I did buy the dual valvesprings/retainers from him too...also...should i run the stock Si ECU??? What do you guys recommend to take advantage of the higher rpms these parts are capable of???
Old Nov 13, 2008 | 04:44 AM
tercel95's Avatar
btw cams are worthless without tune. I have skunk2 stage 1 with valvetrain (w/o tune) and the car barely has anymore power, but runs extremely rich (black soot everywhere). However, the vtec crossover is significantly more dramatic...
Old Nov 13, 2008 | 08:26 AM
1SloNeon's Avatar
Default Re: (tercel95)
I know thats why i asked what should be done and used to tune the car with the ITR parts installed???????
Old Nov 13, 2008 | 08:58 AM
HitF8's Avatar
you should run a chipped ECU and get it tuned for sure
Old Nov 13, 2008 | 09:45 AM
1SloNeon's Avatar
Default Re: (HitF8)
I do have a p30 laying around from my old beater civic i suppose i could have chipped and run a conversion harness. Where should i send it to be chipped and what program should i run???? I only have basic bolt-ons (I/H/E) right now and plan on keeping the car pretty lightly modded.
tooth_dr
15
Jul 1, 2010 01:00 PM
realis9
Feb 16, 2007 05:13 AM
Sprockets
Dec 1, 2006 12:30 PM
DeviousLude
Dec 21, 2005 08:54 AM
2ndgent3g
Nov 1, 2004 07:58 PM
