B16 swap Harness question
Old Sep 25, 2008 | 09:17 PM
:::SIRll_EJ1:::'s Avatar
Default B16 swap Harness question
So i'm putting a 0bd2 SIRll in my EJ and I was wondering if the obd2 SI harness would work
I read somewhere on the net that it HAD to be a 94+ integra harness due to its "two piece design"
just wanted to see if this was true
thanks,
-Ray
Old Sep 26, 2008 | 04:14 AM
RyanA's Avatar
Default Re: B16 swap Harness question (:::SIRll_EJ1:::)
They are COMPLETELY different. As stated, the Integra/EJ use a 2 piece harness. 96-00 uses a one piece harness. So..... NO, you can't use it (easily) on your car. Get the EX harness or an Integra GSR harness to minimize the problems. If you weren't sure on the harness, are you sure you want to try to put this in your car by yourself?
Old Sep 26, 2008 | 06:30 AM
ExCon's Avatar
Default Re: B16 swap Harness question (RyanA)
Use your stock harness and add Vtech wiring.
Old Sep 26, 2008 | 10:33 AM
Default Re: B16 swap Harness question (ExCon)
yeah im positive
im doing the swap is so i can learn
reakky dedicTED and am doing tons of research
just askin around honda-tech cuz u guys are so helpfull =]
and ive already learned alot by building the b16
I'm gunna pick up a gsr harness now haha
alls i need now is a b16a1 ecu
thanks lot man
TwoKSiR
Dec 18, 2008 10:28 AM
turboteg90
Jun 10, 2008 12:13 PM
EF7
Sep 25, 2006 09:06 AM
Beau Gotti
Feb 12, 2006 02:11 PM
v-tec maz
Jan 8, 2006 07:01 PM
