can't get bolt out?
Old Sep 25, 2008 | 12:39 PM
corkss's Avatar
Default can't get bolt out?
I'm having a little trouble getting the bolt where the lower control arm bolts up to the lower shock fork...One side came out normal...the otherside seems to be stuck on the bushing...
What do I do??.. would an impact break it loose?
THaks
Old Sep 25, 2008 | 01:16 PM
Unit44justin's Avatar
go to you local hardware store and buy a propane torch heat that bitch up good and it should come right out. You are going to toast the bushing so you will need to get a new bushing for it or get some different LCAs
Old Sep 25, 2008 | 04:05 PM
chickenwing's Avatar
try the impact and if not then it is torch time
Old Sep 25, 2008 | 04:10 PM
Frickr's Avatar
Default Re: (chickenwing)
i ended up having to cut off the shocks, order new ones, and new bushings. tried heating it with a torch and nothing. dont bother drilling it, it doesnt work.
Old Sep 25, 2008 | 05:19 PM
grandtheftlunchbox's Avatar
Default Re: can't get bolt out? (corkss)
this happened to me two days ago. here's what i did...
1. break the head of the bolt off.
2. break off the nut that is tack welded to the shock.
3. take a pry bar and pry the foot of the shock away from the lower control arm, and grind the threaded end of the bolt off between the shock and the LCA. once this is done, you should be able to work the shock off the LCA.
4. borrow a ball joint remover from a friend and use the fittings to press the old bushing out of the LCA. this may take some trial and error.
5. press new bushing in, and put 'er back together.
hope this helps.
Old Sep 25, 2008 | 06:21 PM
sirEGhatch's Avatar
the head of the bolts snaped off on me on both sides. i just got new control arms. 2nd car i had this happen to me on.
IntegraR0064
Jul 28, 2010 09:38 AM
vteck1ck
14
Nov 14, 2008 08:55 PM
sohc_student
Suspension & Brakes
Sep 4, 2006 11:05 PM
mikehawkBUiLT
15
May 13, 2004 03:17 PM
ophdehEEzY
Sep 8, 2003 04:53 PM
