car alarm broke doors stuck locked
Old Sep 25, 2008 | 11:39 AM
92nahatch's Avatar
Default car alarm broke doors stuck locked
i bought my eg with an alarm system in it it recently stoped working. when i turned the key it locked me in and when i turned it off it unlocked then one day i turn it off and my doors wont unlock how or what can i do to unlock my doors. can i hook the wires that go to my door to a 12v spot or how do i make it unlock plz someone help i feel like bo duke climing in the window all the time im sick of it
Old Sep 25, 2008 | 11:50 AM
JSPECSIR's Avatar
Default Re: car alarm broke doors stuck locked (92nahatch)
have you tried moving the lock lever with your hand? or using the key in the door keyhole? alot of civics dont have power door locks. i fail to see how your manual lock mechanism would work any differently if the power is not working.
Old Sep 25, 2008 | 12:04 PM
honda_joe's Avatar
Like JSPECSIR said, you should be able to use the manual mechanism to unlock the door (right next to the interior handle). Sometimes people disable the mechanism to make it harder to break in. You should be able to take off the door panel and see whats needed to reconnect everything. The locking system isn't too terribly complicated.
Old Sep 25, 2008 | 03:28 PM
92nahatch's Avatar
Default Re: car alarm broke doors stuck locked (honda_joe)
well they disconected the lock/unlock lever in the car and i tryed with my key and it wont unlock. there are 2 wires that go from the alarm into the doors
Old Sep 25, 2008 | 03:31 PM
92nahatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_joe &raquo;</TD></TR><TR><TD CLASS="quote"> You should be able to take off the door panel and see whats needed to reconnect everything. The locking system isn't too terribly complicated. </TD></TR></TABLE>
the door wont open how do u spose i take the door panel off?????
Old Sep 26, 2008 | 12:00 PM
92nahatch's Avatar
bump
Old Sep 26, 2008 | 07:57 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch &raquo;</TD></TR><TR><TD CLASS="quote"> there are 2 wires that go from the alarm into the doors </TD></TR></TABLE> cut those wires loose from the alarm, strip the set going into the door. then if you have a drill battery or something close to 12v touch the wires to the terminals and see if it unlocks. if not reverse the wires and try again. if you dont have a battery run some speaker wire to your car battery and use it to pulse the wires with power to unlock it. BE VERY CAREFUL DOING THIS IF THE WIRES FROM YOUR BATTERY SHORT OUT THEY CAN CATCH ON FIRE AND BURN YOU/CAR. hope this helps.
Old Sep 26, 2008 | 08:06 PM
fcm's Avatar
fcm
Old Fart
the door wont open how do u spose i take the door panel off?????</TD></TR></TABLE> Sounds like he disconnected the key cylinder linkage also.
You say, "there are 2 wires that go from the alarm into the doors " so I would assume the power door locks are aftermarket and the relays for lock/unlock are "built in" to the alarm, the two leads go to the actuator, cut the two leads from the alarm, ground one lead to cars chassis and supply 12V+ to the other lead, if door does not unlock, reverse the polarity, [ground the other lead to the chassis and supply 12V+ to the other one] door will unlock one way or the other.
I guess I don't have to tell you what a PITA disconnecting door lock linkage can be, and if you think about it, kind of pointless as a security measure, unless of coarse you have some sort of ballistic glass, and you do know a crook will just bust your window to get in. 94
Old Sep 28, 2008 | 05:28 PM
92nahatch's Avatar
Default Re: car alarm broke doors stuck locked (fcm)
see that what i thought i tryed applying 12v to one and grounding the other and it did nothing ill go try it both ways again thanx for the help ill let u know if it works out
Old Sep 28, 2008 | 07:05 PM
digdug18's Avatar
i reccomend using a baseball bat to get you into the car preferably one of the windows, as both the windshield and back glass are a pain to get through, just be warned that you'll be cleaning up for hours afterwards getting all the shards outta your seats.
have you tried the trunk key hole? It shouldnt have anykind of bypass to it, and the key should still work to allow you to crawl inside.
If you could tell me the year and body style of your car I could give you an easier way to get inside without doing as much damage to your window.
Andrew
Old Sep 29, 2008 | 04:55 AM
fcm's Avatar
fcm
Old Fart
If supplying power and ground to the two leads going to the door lock actuators does not work, it could be that the actuators are burnt out. 94
Old Sep 30, 2008 | 02:19 PM
92nahatch's Avatar
yep they are burnt out but i pulled the top of the door pannel away from the door and reached in and unlocked both doors and then i reconected the regular locks that were all just disconected but the rods were still in there
thanks for the help
Old Sep 30, 2008 | 06:10 PM
fcm's Avatar
fcm
Old Fart
A bit of a pain, but possible to do without damaging the panels, it would have been my next suggestion, how did it go? 94
Old Oct 1, 2008 | 03:22 PM
92nahatch's Avatar
my arm has some scrapes on my arm but it went ok
importdude2000
Audio / Security / Video
12
Jun 20, 2011 06:54 PM
jdmer329
Oct 10, 2010 08:35 AM
Ran4it2
10
Nov 26, 2008 09:34 PM
qwik92hatch
Honda Civic (2001 - 2005)
May 12, 2006 12:07 PM
dut
Jun 30, 2003 06:35 PM
