1990 honda crx ?
cylinder lock....
0. unplug the battery/ or unplug the two clips that run to the ignition.
1. remove the plastic steering column covers.
2. put the key in.
3. it has a small hole on the top with a little pin that needs to be pushed down
I used a coat hanger.
4. I can't remember what position the key has to be in but press the button with
the coat hanger and try to pull it out if it doesn't come out go to the next position.
5. Remember that nothing comes out with force.If its not coming out make
sure your pressing the pin in and that the key is in the right position.
(sorry i don't remember exactly what position it has to be in.
2. put the key in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guysensei »</TD></TR><TR><TD CLASS="quote">cylinder lock....
2. put the key in.
2. put the key in.
mucjbpe
May 8, 2014 06:38 PM
efrex
Mar 1, 2007 07:58 AM
jondancer
Jun 1, 2003 09:12 AM
