FS: 2001 NHBP ITR 99k great condition, MD
Since people can't read... I AM NOT INTERESTED IN TRADES I ALREADY HAVE MY NEXT CAR. FOR SALE FLAT OUT ONLY!!!!!!
2001 NHBP ITR
99,600 miles on it
Located in MD.
clean title, clean carfax report...
PS
A/C
Mods:
- Ground Control Coilovers and Koni Yellow Shocks
- Skunk2 front and rear camber kits
- JDM ITR shift boot
- Brand New ITR floor mats
- JDM Window Visors
- JDM Sidemarkers
- 4300k Xenon Depot HIDs (+ I will give you one extra bulb)
- Front and Rear Red H Emblems
- Rear Honda written out Emblem
- S2000 antenna with kit so it actually works (awesome quality)
- JDM 98-01 Rear Tail lights
- Mishimoto aluminum radiator & slimfan
- Spoon radiator stays
- Front OEM and rear UKDM fog lights with switch
- Fujitsubo RM01a exhaust/high flow cat
- AEM Fuel Rail
- I have also spent over 1500 in security measures which I will only discuss with the next owner of this car..
In addition I have replaced the following =
- at 88k: timing belt, water pump, camshaft seals, a/c and p/s belts, alternator belt, and o2 sensor replaced, new battery
- replaced driver's side front axle due to previous owner having a crappy aftermarket one, both outer tie rod ends, and left front sway bar link
- at 93k: replaced power steering canister and hose due to small leak and put in new PS fluid, replaced the fuel rail with an AEM one and replaced the fuel lines and canister with OEM one (previous owner had unnecessary steel braided lines), installed new OEM mudguards, new front fender liners, replaced exhaust hanger bushings, replaced tranny fluid, flushed and put in new brake fluid, PCV valve replaced.
- at 99k: new radiator hoses and coolant, spark plug wires, replaced clutch master cylinder, got a full alignment, brand new front bumper and lip
The bad:
- the car is throwing one code, P0420 – catalyst below threshold (usually means cat needs replacing)
- latch to open trunk does not work – have to use key
- previous owner took out windshield washer reservoir but I have one if you want it
I am asking 15,000 for the car. This is ITR # 01-0618. Please PM me with any questions. Serious buyers only..
2001 NHBP ITR
99,600 miles on it
Located in MD.
PS
A/C
Mods:
- JDM Window Visors
- JDM Sidemarkers
- AEM Fuel Rail
The bad:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. »</TD></TR><TR><TD CLASS="quote">ill give you $1500, final offer
you forgot the other 0
hahahaha
</TD></TR></TABLE>you forgot the other 0
hahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightweight_ »</TD></TR><TR><TD CLASS="quote">trade for the midori? lol</TD></TR></TABLE>
i already have my next car lined up hopefully
