FS.----------H2D Fully built h22 LSD d16 tranny H2D swap----------
Fully built H2D Swap For Sale or trade + cash
H2D
Im testing the waters on my H2D swap. The motor was built by CC imports last year. I have 690 miles on the swap and about 1000 more on the tranny. Im just taking offers as of now. I have a few new projects that need to get done and i have no use for it any more since i sold the shell it was going into.
H22 Motor
Head-
*JGE Dual Valve Springs
*JGE Titanium Retainers
*JGE stainless steel racing valves (High Comp NA)
*oem valve stem seal
*Stock h22 cams but will add Crower stage 3 Cams
*Aem Cam gears
*Greddy blue timing belt
*Stock intake manifold with (direct port N02 Kit and bottle and lines) Or Skunk2 manifold with 70mm tb
*Hondata intake gasket
*Camp1320 H2B header
Block-
*H22 block
*F22 Crank
*F22 rods
*H22A4 Pistons (Compression ratio over 10.96:1)with the high comp valves
*Fully blueprinted, balanced, micro polished
*custom motor mount
*balance shaft eliminater
*Alternator Relocater Bracket w/ d-series alt
Tranny-
*D16z6 tranny (from 95 civic si) About 1000 miles after build
*Obx LSD
*BisiMoto Full H2D Kit
*Exedy Stage 1 clutch
ECU-
*Chipped P28 with crome H22 base map
The only thing I will trade for is a Honda or another swap + cash. I dont know just throw up some offers. Thanks, Paul
Modified by dragpro at 5:15 AM 9/25/2008
Modified by dragpro at 6:49 AM 9/25/2008
H2D
H22 Motor
Head-
*Aem Cam gears
Block-
*H22 block
*F22 Crank
*F22 rods
*custom motor mount
Tranny-
*Obx LSD
ECU-
