how do you tell if your clutch is slipping?
Old Sep 24, 2008 | 10:20 PM
RA050826's Avatar
clutch is fine!!!
Modified by sparcoboi77 at 11:57 AM 10/3/2008
Old Sep 24, 2008 | 10:58 PM
Redemption's Avatar
Default Re: how do you tell if your clutch is slipping? (sparcoboi77)
I have never had my clutch to that point but you will feel a noticeable loss in power especially if you are trying to up hill and the car is some what full. Like it will have trouble accelerating.That is what I have heard from people.
Old Sep 24, 2008 | 11:35 PM
garados's Avatar
Default Re: how do you tell if your clutch is slipping? (Redemption)
nah, that just means you're low on power Anyways, go on the freeway and just stomp on it in 5th gear. If the rpm's rise and the speed doesn't go up fast enough for that increase in revs, the speed stays constant, or the speed drops, the clutch is slipping.
Old Sep 24, 2008 | 11:55 PM
RA050826's Avatar
Default Re: how do you tell if your clutch is slipping? (garados)
well i noticed it doesnt pick up in 2nd and 3rd the rps kinda go faster then they shpuld but then i hit 5th it grabs good
Old Sep 24, 2008 | 11:56 PM
RA050826's Avatar
oh **** mai just noticed your from albuquerque i used to live there half my life i lived my the cornado mall
Old Sep 25, 2008 | 12:30 AM
garados's Avatar
haha, oh damn! yeah, I just moved up to Colorado ... I should update that Yeah, if the rpms rise faster than the speed, it's slipping. When it starts doing it in 5th, then I would really consider getting a new clutch.
Old Sep 25, 2008 | 01:46 AM
ls_bitik's Avatar
put in ebrake and 1st gear. release clutch slowly, youll feel if it is slipping or not.
Old Sep 25, 2008 | 04:48 AM
HONDRETTI's Avatar
you can try all of the above, or simply put it in first, load up a couple thousand rpms and drop the clutch. if it grabs very well and spins your tires youre good, of course considering what clutch you have.
Old Sep 25, 2008 | 06:01 AM
steveo135's Avatar
Default Re: how do you tell if your clutch is slipping? (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bugs bunny &raquo;</TD></TR><TR><TD CLASS="quote">
musta taken the wrong turn in albuquerque</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados &raquo;</TD></TR><TR><TD CLASS="quote">If the rpm's rise and the speed doesn't go up fast enough for that increase in revs, the speed stays constant, or the speed drops, the clutch is slipping. </TD></TR></TABLE>
Old Sep 25, 2008 | 06:25 AM
AWD Terror's Avatar
Default Re: how do you tell if your clutch is slipping? (steveo135)
I would not use 5th. If your clutch is slipping in 5th, then it is non existent.
Use 3rd. Slowly get your rpms up to about 4k. Then stomp on it. If your rmps go up without your speed increasing, then your clutch is on it's way out.
You can also tell from the smell.
Old Sep 25, 2008 | 03:57 PM
RA050826's Avatar
Default Re: how do you tell if your clutch is slipping? (AWD Terror)
thanks guys ill tyr that right now and ill keep you posted on what happens
Old Sep 27, 2008 | 09:09 PM
RA050826's Avatar
ok my clutch is fine lol i dont know why i thought it was slipping
Old Sep 27, 2008 | 09:18 PM
LordAphotic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparcoboi77 &raquo;</TD></TR><TR><TD CLASS="quote">ok my clutch is fine lol i dont know why i thought it was slipping</TD></TR></TABLE>
live and learn... what really was it?
Old Sep 27, 2008 | 10:28 PM
veilsides2000's Avatar
If you have cruise control then use that. If it turns off then your clutch is pretty bad.
Old Sep 30, 2008 | 09:42 AM
RA050826's Avatar
Default Re: how do you tell if your clutch is slipping? (veilsides2000)
yea i think its fine i dont know what is was but its coo now thanks for all the advise
mr_munro
Oct 24, 2012 05:54 PM
ic89
Oct 16, 2006 02:44 PM
bucknuts
Apr 5, 2005 04:27 PM
gsrXredline
Dec 11, 2002 11:36 AM
LOwrestling2001
May 26, 2002 03:28 AM
