compression vrs displacement.
Old Jul 26, 2002 | 01:16 PM
RiCE On IcE 2's Avatar
Default compression vrs displacement.
quick question does higher compression take presidence over larger displacement, I'm not talkign a huge change in displacement, but like say u change ur pistons and u get domed ones and had concave ones. This I beleive would lower displacement, but increase compression in this case does the compression chagne make more power then the loss in displacement?.. I was jsut wondering cus liek when u raise ur compression normally dun ur displacement get lowered unless the engine stroke is longer?
Old Jul 26, 2002 | 03:02 PM
sgT's Avatar
sgT
Default Re: compression vrs displacement. (scmdl26)
displacement is dependant on bore and stroke only. nothing else.
Old Jul 27, 2002 | 04:22 AM
DutchITR1689's Avatar
Maybe you think displacement is the total volume of the cylinder, that's why you are thinking this way.
Old Jul 27, 2002 | 09:43 AM
Default Re: compression vrs displacement. (DutchITR1689)
oh yea.. displacement is the total voume the piston moves huh, like it's not the whole cylinder jsut the are the piston covers right?
[Modified by scmdl26, 6:44 PM 7/27/2002]
Old Jul 27, 2002 | 10:50 AM
aet6's Avatar
The displacement of a coke can is 12oz...
if you could put something else in the can, like a small piston, you have raised compression(of the liquid coke), but your displacement has stayed the same.
The 2 arent related in the way you were thinking...
aet
Old Jul 27, 2002 | 11:34 AM
hooptie157's Avatar
Default Re: compression vrs displacement. (aet6)
aet
hooptie clapping his hand cause he was thinking the SAME thing
Old Jul 29, 2002 | 02:15 PM
aet
ok so yea I gotta disagree with u well with context to cars at least.. it's jsut the differnce in volume of the cylinder when piston is TDC and BDC (up and down), ur coke can works but not in the context I'm looing for but nevermind neway
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
EastSideRacer
K Series
Mar 24, 2010 06:49 PM
kornerk12
Jan 5, 2006 07:20 PM
Tee Jay
Jul 11, 2003 12:10 PM
MaD3 In JaPaN
Jan 7, 2002 06:33 AM
