what is all needed to swap a b18c1 into a 88-91 ef 2 door and 4 door? Usa da mounts? what about shif
what is all needed to swap a b18c1 into a 88-91 ef 2 door and 4 door? Usa da mounts? what about shift linkage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80 dolla crx hf »</TD></TR><TR><TD CLASS="quote">I did i only come up with b18 swaps into everything else
i cant find **** for the ef 4 door</TD></TR></TABLE>
It's the same for an EF sedan as it is for any other EF Civic hatch or CRX... the engine bay's are the same. You're gonna need an EF B series mount kit and matching shift linkage from the same company you get the mounts from OR you can modify (shorten) DA Integra linkage. If you plan on using a hydro tranny, you'll need a conversion kit for that too.
The Alchemist...
18
Jan 21, 2005 04:03 AM
