NEED help with B16A2 Build
I'm building a B16 and the crank pulley moves freely and the crank just stays still.
my friend told me something about a "keyway" but im not sure if he was right, I also tried to google the issue and have been searching threads and cant find anything.
If Anyone knows what the deal is with the pulley and crank PLEASE let me know
Thanks,
-Ray
Thanks,
-Ray
there should be a key that goes in. It' pretty much is a rectangular box shape. If you take the crank pulley bolt off and then take the crank pulley off, you'll see the groove on the crank and the crank pulley that the "key" is suppose to go into
its called a woodruff key, most autopart stores carry an assortment pack of them in the help section. I would recommend picking one up from your local dealership just to make sure you have the correct one.
