Tailight water leak EK OWNERS HELP!
Old Sep 24, 2008 | 07:06 PM
FRKWOO's Avatar
Default Tailight water leak EK OWNERS HELP!
posted a thread in the beginning of this week with the problem of my taillights leaking water into the trunk of my hatchback. everyone said i needed new taillight gaskets, bout 2 new ones from the dealership and didnt fix my problem. rain still gets in the trunk when it rains through the taillights. anyone has anymore suggestions on what to do to fix this issue? thanks
Old Sep 24, 2008 | 07:18 PM
makavali27's Avatar
Default Re: Tailight water leak EK OWNERS HELP! (FRKWOO)
I had the same issue..what i did was get some clear silicon from homedepot and put a layer around the taillight back..so water can't leak into trunk, so make it nice and make sure to cover it up well.should solve the problem..
Old Sep 24, 2008 | 07:52 PM
FRKWOO's Avatar
Default Re: Tailight water leak EK OWNERS HELP! (makavali27)
what do u mean by the back of the taillight the part that touchs the car or glue the gasket to the tailight?
Old Sep 24, 2008 | 08:37 PM
makavali27's Avatar
i put a nice thick layer around that and it seemed to have stopped the leak..
Old Sep 24, 2008 | 08:40 PM
makavali27's Avatar
sorry i don't know why it got small..but u can see it..
Old Sep 24, 2008 | 08:46 PM
FRKWOO's Avatar
so i wouldnt be able to take on and off the taillights anymore?
Old Sep 24, 2008 | 08:51 PM
hgem1si's Avatar
Yeah you would, you'd just have to reapply silicon. Der! It's pretty inexpensive, and I don't see why tail lights would come on and off repeatedly.
Here's an idea, don't live in Seattle. lol
Old Sep 24, 2008 | 09:04 PM
FRKWOO's Avatar
Default Re: Tailight water leak EK OWNERS HELP! (hgem1si)
what kind of silicon should i get and thanks for all the help so far guys thanks
Old Sep 25, 2008 | 07:24 AM
chino239's Avatar
i have the same problem
Old Sep 25, 2008 | 07:30 AM
tony tone's Avatar
GDD Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hgem1si &raquo;</TD></TR><TR><TD CLASS="quote">
there's your answer.
Old Sep 25, 2008 | 08:49 AM
The Collin's Avatar
Common problem. A nice strip of silicon will do the trick. Only way I've found to fix the issue.
Old Sep 25, 2008 | 09:21 AM
Abius's Avatar
Default Re: (99_hb_on_air)
You should check in your rear quaters for a hole. I thought I had the same problem of water being let in by holes where the taillights are. But after testing if water goes in there it didnt.
THere was a hole on the driver side near the gas tank line. Dirt collected there corroded the **** out of the corner, and now theres a hole
Old Sep 25, 2008 | 02:09 PM
FRKWOO's Avatar
Default Re: (Abius)
anymore advice?
Old Sep 25, 2008 | 04:00 PM
tony tone's Avatar
GDD Moderator
Default Re: (FRKWOO)
hide in your trunk, have someone ridiculously water hose your read end (car ofcourse) and detect the leak. silicone is your best friend from there on forward.
Old Sep 25, 2008 | 08:47 PM
makavali27's Avatar
Default Re: (tony tone)
i think we pretty much summed it up for you..
airikkCRX
Feb 7, 2011 09:55 AM
TurboGS-R
Apr 2, 2006 10:32 PM
quagabow
47
Oct 19, 2004 05:10 AM
EGTeK
Feb 24, 2003 12:02 PM
