axles for engine swaps??
i have an 88 crx si.
B18a1 swap with B16a tranny.
my axles just recently went bad but i dont know what to get to replace them.
few questions pop into my head..
-length??
or
-splines?
which do i get?
Si axles? or CRX axles?
-length??
or
-splines?
which do i get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayhelladum »</TD></TR><TR><TD CLASS="quote">i think i already have DA knuckles. but would those axles fit the Si tranny?</TD></TR></TABLE>
You already said that you have a B16 tranny which would mean you're not running the Si D series tranny, which really isn't possible without fab work... If it's a cable B16 tranny, hopefully you don't have the JDM intermediate shaft in which case you can use stock 90-93 DA axles.
Si axels = CRX axles... both are D series and not equal length and won't work with a B series setup.
I had this problem not ot long ago with my driviers side axle, I have the same set up and I'm using da 91 ls axles but the intermediate shaft was to short so everytime the car was lifted the axle fit fine but when I set it down it pulled the axle bearing to far out of the inner cv joint i had to get a sir intermediate shaft cause its 1" longer than the ls one and now it works fine.
by si i meant the B series Si tranny. sorry if i wasnt clear. i thought throwing the fact that i have a bseries swap would eliminate the dseries tranny in the question.
so i with that said.. DA axles it is. unless someone says other wise
LurkerS8
17
Jun 25, 2005 07:46 AM
