tie rod problem
Old Sep 24, 2008 | 10:54 AM
Firefoxracer's Avatar
Default tie rod problem
i had 95 integra front spindals on my crx and they fit fine.. swaped them to my 94 del sol and the tie rods dont seem to be long enough at least not for peace of mind. any one have any ideas. i work at NAPA autoparts and looked up the ones for eg. ek and dc cars and they are all the same part number for inner and outer tierods. Im guessing that the difference is the steering racks being different length. the only ones i havent checked on is for Ef cars. A friend told me he founds some longer tierods on line dont remember the site. any one ever heard of longer ones made for swaps like that?
Steve
Old Sep 24, 2008 | 11:03 AM
riceburnerryan's Avatar
i thought that the EG and the DC had same suspension..
but then again you are doing it on a Del Sol... is the Del Sol part number the same as the EG and DC one?
Old Sep 24, 2008 | 11:05 AM
twinksack's Avatar
* B A N N E D *
Default Re: (riceburnerryan)
have you tried adjusting the tie rods
Old Sep 25, 2008 | 06:31 AM
Default Re: (twinksack)
used the integra spindals for the large brakes. where the tierod conects onto the spindal it is further away from the tierod i adjusted them to where they are closer to alignment but i think 1 full rotation would disconect the inner tirod from the outer... thats why i need longer ones... accord outer tierods are about 1 inch longer but that might be to long....
part numbers are the same for iner and outer for eg-ek and da.
Old Sep 25, 2008 | 07:08 AM
90_EX_Civic's Avatar
Default Re: (Firefoxracer)
i think your problem might not be the end links but the rod it self. you might need to compare the rods with each other not the end links.
Old Sep 26, 2008 | 12:25 PM
Default Re: (90_EX_Civic)
end links are also the same. i found in some forums that integra and civic spindals have differnt length mounting points for the tierods the little arm that the tierod goes into on the back side of the spindal. the del sol is longer for a better turning radius then the integra due to wheel base and other issues. the only option i could do is change the steering rack to an integra but thats a little costly and time consuming. so im going to use the accord tierod ends that are almost an inch longer and if they are to long then ill cut the inner tierods to compensate for the extra distance.
if any one else has ideas or sujestions let me know.. havent decided for sure yet what to do for sure.
Old Oct 18, 2008 | 01:57 PM
jdmforeel's Avatar
i think we have pretty much have the same problem...i just did a gsr front and rear disc convertion brake to my 94 civic hatchdx..after i finished the install and i recognize that my steering are unstable..can someone identify this problem please...SORRY didn't mean to jack your thread
Jdmhondaowner
Apr 16, 2014 02:54 AM
da_driver_15
13
Jan 7, 2011 05:34 PM
kristianhay
Mar 8, 2010 12:25 AM
superdelsol
Jun 7, 2007 06:52 PM
SofaKing
Dec 31, 2003 03:30 PM
