just got my transmission in and having a little problem downshifting to 2nd.
Old Sep 23, 2008 | 11:38 PM
unsungfate's Avatar
Default just got my transmission in and having a little problem downshifting to 2nd.
ok so its a 98 itr tranny with stock lsd. it shifts and runs like a freakin' dream. my only complaint or problem is when im downshifting to second. i was told it was normal.. but how much of it is normal??
example:
i will cruising up to a pretty slow corner "like turning onto a street" in 3-5th gear. depends how fast im going and it happens downshifting from either gear, and i go to shift into second to not only engine break into the corner and pull out of the corner midway like i like to so much and it just kinda gets stuck at the gate. and i have to double clutch and kinda force it into the gear..
would really like to know if this is normal on these trannys' and if its ok that i double clutch into second like that on a downshift. i spent a pretty penny on this pretty tranny and i would be so mad and sad if im screw it up.
Old Sep 24, 2008 | 02:20 AM
jdmjohnyyy's Avatar
Default Re: just got my transmission in and having a little problem downshifting to 2nd. (unsungfate)
idk but, is there fluid it the tranny ?
Old Sep 24, 2008 | 07:32 AM
unsungfate's Avatar
Default Re: just got my transmission in and having a little problem downshifting to 2nd. (jdmjohnyyy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjohnyyy &raquo;</TD></TR><TR><TD CLASS="quote">idk but, is there fluid it the tranny ?</TD></TR></TABLE>
i shouldn't be allowed near vehicles if i forgot to add fluid to this beautiful tranny..
yes it got filled up with new sexy royal purple lube.
Old Sep 24, 2008 | 07:40 AM
Vindicator9000's Avatar
318 Curves, 11 miles
What rpm and what gear are you downshifting from? What rpm are you at when you get it into second?
If you're doing a major downshift (like 4000 rpm in 5th), I'd say that's normal. If you're doing a minor one (like low rpm 3rd to 2nd), I'd say that's not normal.
Old Sep 24, 2008 | 07:49 AM
unsungfate's Avatar
Default Re: just got my transmission in and having a little problem downshifting to 2nd. (Vindicator9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 &raquo;</TD></TR><TR><TD CLASS="quote">What rpm and what gear are you downshifting from? What rpm are you at when you get it into second?
My down shifts are probably around 3-4k in third gear into second.
Jesus... a down shift from fifth gear of around 4k into second? I'm not trying to grenade both my transmission and motor..
Old Sep 24, 2008 | 09:52 AM
00b20vtecoupe's Avatar
i would say where did the tranny come from? if its from a person ask if they had any issues but ide say mayb a linkage problem...
envision
Feb 16, 2008 09:21 PM
egekreject
10
Aug 23, 2007 11:29 AM
JDMTegraR
Jul 26, 2005 05:24 AM
usdmcrx
Apr 27, 2003 09:13 PM
GSRwBOOST
Jun 4, 2002 01:41 PM
