Silencer on my Apex Dunk is STUCK
Old Jul 26, 2002 | 12:09 PM
PolySquared's Avatar
Default Silencer on my Apex Dunk is STUCK
I've done this many times before but its on real good this time. I even have a silencer removal tool and I'm pulling the heck out of the sucker and its seems to be on real tight. You guys got any tips to help me out here?
Old Jul 26, 2002 | 12:17 PM
Spade's Avatar
Default Re: Silencer on my Apex Dunk is STUCK (PolySquared)
oil
Old Jul 26, 2002 | 01:51 PM
jg's Avatar
jg
tap around the tip with a hammer(cardboard between hammer and tip). Use a 1/2" ratchet to pull it out-worked for me when mine was stuck. Next time apply some oil around the edge before before it in.
Old Jul 27, 2002 | 11:26 AM
Default Re: Silencer on my Apex Dunk is STUCK (jg)
my silcencer is still stuck. I had never seen this before. Any other tips out there? could muffler places remove it?
Old Jul 29, 2002 | 12:42 AM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
WD-40 around the parts where u think it's stuck...use a hair dryer or a heat gun and warm up the tip...use the tool that u have and just tug and twist...use a hammer to hit the silencer inward, then tug again..it worked on my friends universal dunk...
Old Jul 29, 2002 | 05:24 AM
jweller's Avatar
Default Re: Silencer on my Apex Dunk is STUCK (PEN15teamJDM)
condsider yourself lucky, now you won't even be tempted to drive around making that awful lould noise.
bag the wd-40 and get pb blaster. spray liberally and let it sit for a min and then tap the tip with a hammer. if that doesn't work, run the car to heat it up and, being careful, try to pull it out while it is still hot or at least warm. you'll need a pair of mechanix gloves for that.
the other thing you can try is to go to a hardware store and get an expansion nut. they use them to hang stuff on drywall where there isn't a stud. anyway they kinda close up and slide through a small hole, and then expand. you could slip something like that throgh the small pipe in the silencer, and pull with that. this way you wouldn't damage anything, but you could put a pair of vice grips onto it and pull hard
Old Jul 29, 2002 | 05:37 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Silencer on my Apex Dunk is STUCK (jweller)
my silencer got stuck on my n1...i used wd-40 when it was kinda warm...and i pulled the heck out of it with some pliers....i pulled one side at a time..for example i pulled the top out a little then the bottom then the top again moving it out little by little ...after about 10 mins it came out..my silencer was a bit bent after tha but no biggie i just leave it off now anyway ....just thought id help you out...
Alexander
Mar 25, 2004 05:31 PM
crossedover
Nov 16, 2003 01:35 PM
droppedcivo
Apr 22, 2003 09:53 PM
iam7head
Sep 9, 2002 02:02 PM
Integra_Boi
Mar 13, 2002 08:22 PM
