Need help with chain and sprocket selection(77 750-4)
I know there are a few of you guys on here that tinker with older bikes and as the title states I am in need of a new chain and a front sprocket. The rear looks fine(no bent or curved teeth so if I could get away with keeping it for a while I would like to. I am aware that they should both probably be changed when replacing the chain.
The bike is a 1977 Honda 750-four, the old chain broke a roller at the master link and as I search the vast array of chains and the minimal support of sprockets I and kinda at a loss.
So far the stock specs are:
Chain: 630QR at 44 links( I would prefer to find an o-ring chain but have heard good and bad about them on the older bikes) and from all of the other specs I have found it came stock with a 530
Front sprocket: 15 tooth, I would like to go up a tooth and lower my highway R's
Rear: 41 tooth maybe go down 2 or 3 teeth, again for highway travel.
Does anyone have any input on this that might steer me in the right direction?
Modified by CornerCarvin at 2:57 AM 9/24/2008
You can get 530, or 520 sprockets from sprocket specialists if you want to go smaller, in a range of sizes.
If you want to reuse the sprockets then flip them over.
I would never reuse sprockets since they are just as much of a wear and tear item as the chain. A chain sprocket combo work together and wear together. Go 520 since the price probably won't be any different and it'll save a little rotating weight. As for the chain, go with an x-ring chain (DID gets a
from me)
from me)
does anyone know where I can get a 530 chain and sprocket conversion kit for this bike?
So far all i can find is a rear sprocket and chain from sunstar and DID, I can't seem to find a front and I have been looking all day. I kind of figured that I would have to piece something together and I would like to stay with steel sprockets for the sake of wear and maintenance.
I'm not sure where you can get the front but a hard anodized sproket is just as strong as a steel. Also, front sprockets only come in steel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CornerCarvin »</TD></TR><TR><TD CLASS="quote">does anyone know where I can get a 530 chain and sprocket conversion kit for this bike? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">You can get 530, or 520 sprockets from sprocket specialists if you want to go smaller, in a range of sizes.</TD></TR></TABLE>
http://www.sprocketspecialists.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH »</TD></TR><TR><TD CLASS="quote">a hard anodized sproket is just as strong as a steel</TD></TR></TABLE>
Still wont last as long.
integraautox
Honda Motorcycles
Sep 25, 2004 10:25 AM
