Tachometer Issue, RPM sticking 05 rSX
Old Sep 23, 2008 | 09:33 PM
AgEnT-'s Avatar
Default Tachometer Issue, RPM sticking 05 rSX
I have an 05 rsx base auto. RPMs are not a huge deal, but im trying to figure out what is wrong with my tachometer..
The car is idling at almost 0-100rpm.. and it sticks at 800rpm no matter how fast i am accelerating. My car does not have any problems with driving and everything else on the cluster works fine. I did the diagnostic test to see if the RPMs could swing from 0-redline but they would get stuck. I took off the glass cover piece to the cluster and manually moved the rpm gauge. There were several sticking points at roughly 800, 2000, 4000, 5500, and 7500..
Im not sure if its just the cluster that is messed up or there is a problem somewhere. The rpms work fine when i was assisting it past those sticking points. It seems that it is trying to rev up but gets stuck by something.
If you need any other info, ill be more than happy to provide it
Thanks for the help!!
Old Sep 24, 2008 | 03:12 PM
DC5 Maggio's Avatar
Default Re: Tachometer Issue, RPM sticking 05 rSX (AgEnT-)
worst case scenario grab a dc5 type r cluster ftw
Old Sep 24, 2008 | 08:01 PM
AgEnT-'s Avatar
Default Re: Tachometer Issue, RPM sticking 05 rSX (DC5 Maggio)
im prob going to need to get the cluster
no one knows how to fix it
Old Sep 25, 2008 | 09:51 PM
DC5 Maggio's Avatar
look at it on the bright side, you have a good excuse to grab a type r 1 now
Joshua Ramos
Apr 29, 2015 01:43 PM
97cl2.2
Oct 13, 2009 11:33 AM
Aznsensation
Mar 27, 2009 10:14 AM
