b18c1 stock should i put a b16a head?
ask title stated should i leave it stock or should i put the b16 head on? will it make more power? please give me a good advice of what should i do? thank you in advance
If my memory serves me correctly, the b16 head is real similar to the type-r head...hence they call a b18 block with a b16 head a poorman's type-r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1sterpanda »</TD></TR><TR><TD CLASS="quote">If my memory serves me correctly, the b16 head is real similar to the type-r head...hence they call a b18 block with a b16 head a poorman's type-r</TD></TR></TABLE> how much money is it pushin out
If all you're doing is swapping heads then you will LOSE power.
"But why?"
The B16A cylinder head has larger combustion chambers, which lower compression when installed on an otherwise stock GS-R engine. The GS-R engine has lower compression height pistons, but makes it's 10:1 (or 10.6:1 JDM) compression up by having smaller combustion cylinder head chambers.
True the B16A head is the same casting as the Type R, but unless you also swap pistons in that GS-R engine it'll lose compression and thus lose power.
B16A and Type R engines utilize higher compression height/domed pistons than the GS-R engine due to the different sized combustion chambers in the heads.
"But why?"
wasn't there a really good thread on this a few days ago? the bottom line was something like: flow is similar but the quench pads in the p72 head make it more compression friendly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">If all you're doing is swapping heads then you will LOSE power.
"But why?"
B16A and Type R engines utilize higher compression height/domed pistons than the GS-R engine due to the different sized combustion chambers in the heads.</TD></TR></TABLE>
Good info here
"But why?"
Good info here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">read.</TD></TR></TABLE>
SEARCH
SEARCH
lilskud13
Apr 2, 2009 12:38 PM
FairlightRacing
14
Dec 30, 2005 05:08 PM
Slick GS-R
Feb 26, 2004 12:54 PM
