Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Will a 15" wheel clear the brakes on an Si?
Old Sep 23, 2008 | 03:23 PM
markturbo's Avatar
Default Will a 15" wheel clear the brakes on an Si?
Winter is coming and I need a set of winter wheels and tires. I found a set of 15" steel rims with tires that were used on an EX, will they bolt up to the Si and clear the brake calipers?
Thanks
Old Sep 23, 2008 | 04:44 PM
i-VTEC_DOHC's Avatar
nope.
the smallest that will fit on hondas are the size of the spare tire which are 16s on the si
Old Sep 23, 2008 | 05:17 PM
lando griffin's Avatar
Default Re: (i-VTEC_DOHC)
i know they fit in rears, not sure if the front brakes are larger than the rears.
wasn't there just a thread about this?
Old Sep 23, 2008 | 06:42 PM
Default Re: (lando griffin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lando griffin &raquo;</TD></TR><TR><TD CLASS="quote">i know they fit in rears, not sure if the front brakes are larger than the rears.
wasn't there just a thread about this?</TD></TR></TABLE>
i only tried 15 in the front and it didnt fit.
Old Sep 23, 2008 | 07:17 PM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">
i only tried 15 in the front and it didnt fit.</TD></TR></TABLE>
Depends on the offsets and what not.
I had 15" wheels clearing NSX calipers, which are much larger than Civic SI calipers.
Old Sep 24, 2008 | 03:06 PM
E-Town4229's Avatar
Default Re: (TheMuffinMan)
damn is this true? i thought type r wheels would clear. are there base RSX wheels that come in 15"?
-Roger
Old Sep 25, 2008 | 12:57 PM
FijiBlueFG2's Avatar
Road House
Default Re: (E-Town4229)
Why would you want wheels that small? It's designed to run on 17s.
Old Sep 25, 2008 | 01:51 PM
E-Town4229's Avatar
Default Re: (FijiBlueFG2)
the op mentioned for snow tires but i would personally use them for drag radials.
-Roger
Old Sep 25, 2008 | 04:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Town4229 &raquo;</TD></TR><TR><TD CLASS="quote">the op mentioned for snow tires but i would personally use them for drag radials.
-Roger</TD></TR></TABLE>
x2
Old Oct 1, 2008 | 11:51 AM
^AnDre^'s Avatar
What would be the reason for the 15" not fitting, offset and caliper spacing or overall diameter forcing to move to a 16". This would be for Road race application so the offset can be increased to accomidate for the caliper. Has anyone measured?
Old Oct 1, 2008 | 11:59 AM
markturbo's Avatar
Default Re: (^AnDre^)
I went and looked at the 15" wheels and winter tires that were for sale, I tried to mount one of the wheels to the front of my Si in his driveway. Just like the others said, the 15" wheel would not fit, it was close but the wheel hit the brake caliper.
Old Oct 1, 2008 | 12:06 PM
^AnDre^'s Avatar
Default Re: (markturbo)
Which way was it hitting, because of offset (if the rim stuck out more it would fit), or was it the caliper is too large and wont physically fit overtop of the caliper?
Old Oct 1, 2008 | 02:05 PM
markturbo's Avatar
Pretty sure it was the offset. I went to put the rim on and and the studs started to come thru the wheel as I pushed it on, then it hit the caliper and kept the wheel from going on flush. I didn't spend much time looking to see how exactly it was not going on all the way, it just hit the caliper, but I'm pretty sure the caliper was also hitting the wheel in a way that it would rub on it if you were to spin the wheel. So I'm pretty sure it was a combination of both.
Old Oct 2, 2008 | 05:18 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markturbo &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure it was the offset. I went to put the rim on and and the studs started to come thru the wheel as I pushed it on, then it hit the caliper and kept the wheel from going on flush. I didn't spend much time looking to see how exactly it was not going on all the way, it just hit the caliper, but I'm pretty sure the caliper was also hitting the wheel in a way that it would rub on it if you were to spin the wheel. So I'm pretty sure it was a combination of both.
Depending on the offset/wheel design it can fit.
There are fg2's running 15" itr stockers , i've posted pix
Old Oct 2, 2008 | 02:37 PM
Prelusion98's Avatar
Default Re: (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">
There are fg2's running 15" itr stockers , i've posted pix</TD></TR></TABLE>
Still have those photos? I would imagine rather significant spacers would be needed to fit 15" ITR wheels on an FG2. And I still can't help but think that overall diameter of the rotor and caliper setup would prohibit the use of 15" wheels. I'd love to be proven wrong though.
#1 luder
16
Nov 5, 2007 01:03 PM
mikesta
19
Feb 13, 2007 09:45 AM
eMpAtHy
Mar 18, 2005 05:15 AM
RuthlessEF-9
Nov 2, 2004 05:08 PM
Aron Parsons
Apr 22, 2003 07:49 AM
