wiring b16a2, need help?
Old Sep 23, 2008 | 03:12 PM
iamhata's Avatar
Default wiring b16a2, need help?
hi, i am kim , i swap a b16a2 to a austin mini,
my mini
my b16a2
my engine harness but it was cut, when i bought the engine
here is the cut of the harness
and this is the order end of harness
my p30 pcm
my under hood fuse box
my in car fuse box
1. i was looking a wiring diagram for p30ecm
2. for my engine harness (photo4) is cut , that close to the transmission, what does the wire connect to??
3.the engine harness ( photo 5) has 3 connector, that close to the starter, what does it plug .
4.the under hood fuse box wire , where does it connect to
5. i need to order a connector for under dash fuse box, do you have any diagram that show the connector pin
thanks a lot
originalbadbob
May 15, 2004 10:32 AM
sporkcrx
Apr 29, 2003 03:08 PM
