just got an alignment
Old Sep 23, 2008 | 09:56 AM
0_civic_4's Avatar
Default just got an alignment
i just got an alignment on my rex and the rear toe is maxed out. anyway the question is the toe bar of the crx the same length as the DA. i have the rear dsk conversion but i didnt change the toe bar.
Old Sep 23, 2008 | 10:55 AM
reznunt's Avatar
Default Re: just got an alignment (0_civic_4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0_civic_4 &raquo;</TD></TR><TR><TD CLASS="quote">is the toe bar of the crx the same length as the DA. i have the rear dsk conversion but i didnt change the toe bar.</TD></TR></TABLE>
the da arm is longer. did you remove the crx toe arm compensator bolt from the frame of the car at any point during the swap?
Old Sep 23, 2008 | 03:15 PM
wasabivtec's Avatar
Default Re: just got an alignment (reznunt)
what control arm did you end up using
Old Sep 24, 2008 | 10:13 AM
0_civic_4's Avatar
Default Re: just got an alignment (wasabivtec)
i used the 91 SI crx lower control arm. i didnt remove the bolt all the way. i have to much toe in on the back. ill just swap the DA toe bar in and go ge it readjusted
night
Suspension & Brakes
Jun 10, 2011 12:13 PM
BlueRex1020
Oct 8, 2006 12:50 PM
burplelude
Mar 24, 2006 07:27 PM
typesguy
Suspension & Brakes
Feb 24, 2006 11:45 PM
89civicdx
Jul 10, 2001 08:15 PM
