how do you check for vacuum leaks?
Old Sep 23, 2008 | 02:45 AM
chickenwing's Avatar
Default how do you check for vacuum leaks?
just wondering what method and procedure you use to find a vacuum leak?
Old Sep 23, 2008 | 04:20 AM
boostedhks's Avatar
Spray break cleaner around the intake manifold, when you see the idle goes down then that's where the vacuum leak is.or u will see bubbles if it's rlly bad
Old Sep 23, 2008 | 05:03 AM
SOHCammed's Avatar
Default Re: (boostedhks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhks &raquo;</TD></TR><TR><TD CLASS="quote">Spray break cleaner around the intake manifold, when you see the idle goes down then that's where the vacuum leak is.or u will see bubbles if it's rlly bad</TD></TR></TABLE>
Why brake cleaner? Not questioning your methods...just curious.
Old Sep 23, 2008 | 05:22 AM
alright going to do it now.
thanks
Old Sep 23, 2008 | 08:15 AM
socallmechris's Avatar
Default Re: (SOHCammed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCammed &raquo;</TD></TR><TR><TD CLASS="quote">
Why brake cleaner? Not questioning your methods...just curious.</TD></TR></TABLE>
its nice and flammable. so when the car sucks it in, the irradic idling goes away since its burning whats going in. my buddy used a propane tank with a hose to do the same thing on his firebird. he just cracked the valve open a bit and followed all the lines till it went away. then he knew what to fix
Old Sep 23, 2008 | 01:45 PM
SOHCammed's Avatar
Default Re: (socallmechris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socallmechris &raquo;</TD></TR><TR><TD CLASS="quote">
its nice and flammable. so when the car sucks it in, the irradic idling goes away since its burning whats going in. my buddy used a propane tank with a hose to do the same thing on his firebird. he just cracked the valve open a bit and followed all the lines till it went away. then he knew what to fix</TD></TR></TABLE>
Learn something new everyday! Thanks!
Old Sep 23, 2008 | 04:34 PM
batallic's Avatar
soap and water in a spray bottle spray away, if u see bubbles theres yur leak
Old Sep 24, 2008 | 05:16 AM
Default Re: (batallic)
I sprayed everything connected to the intake manifold and where the intake mates to the cylinderhead and did not find any leaks.
Old Sep 24, 2008 | 09:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic &raquo;</TD></TR><TR><TD CLASS="quote">soap and water in a spray bottle spray away, if u see bubbles theres yur leak</TD></TR></TABLE>
wouldn't the vacuum leak your looking for just suck in the soapy water, seeing as it is a vacuum and all?
to the OP:
are you sure you have a vacuum leak? what is it doing? if the idle is jumping it might be a loose IAC giving you a leak also see if the rubber O-ring is bad, that would also cause leak-like simptoms if the sensor is going bad it might act the same way(but that should also throw a light i think)
z28matt
Dec 17, 2009 09:22 PM
mikeunreal2
10
Mar 21, 2006 08:20 AM
Jesterian
11
Feb 22, 2006 11:56 AM
dosJDM
17
Mar 27, 2005 10:08 AM
tkHBseries
Feb 18, 2004 06:21 AM
