Race header Question for RSX
Old Sep 22, 2008 | 09:32 PM
h8ted ek's Avatar
Default Race header Question for RSX
If i get a DCRH, DO i need to get ES "motor mounts"? or ES motor mount inserts????
another question is would it bolt up to stock rsx-s exhaust??
So parts needed installing header is:
o2 extention
defouler
thats bout it right???
Thankkkkkkks, any input would happily appreicated man
Old Sep 23, 2008 | 06:55 AM
h8ted ek's Avatar
Default Re: Race header Question for RSX (h8ted ek)
TTT
Old Sep 23, 2008 | 07:09 AM
simonEp3's Avatar
You will need mounts or inserts either ESMM's, innovative, etc... If you buy a RH it should come with the needed O2 extension wire, but you will need to get the mounts/ defouler. Also, it should bolt up to your stock exhaust fine.
Old Sep 23, 2008 | 11:15 AM
ballerchild's Avatar
you will definitely need some kind of mount/esmm/torque damper. When I installed my dcrh, I ran it for a couple days without one and it would bang against the sway bar going in reverse and every hard shift.
You'll need 1 o2 sensor extension so you don't stretch out your wires and mess them up. And it'll bolt up fine with your stock exhaust.
Old Sep 23, 2008 | 12:06 PM
simonEp3's Avatar
Default Re: (ballerchild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild &raquo;</TD></TR><TR><TD CLASS="quote">...You'll need 1 o2 sensor extension...</TD></TR></TABLE>
Did you not get the extension with your RH my RH came with the O2 extension. JW
Old Sep 23, 2008 | 01:03 PM
DC2 Maggio's Avatar
How hard are the esmm to install. i have this same question. i figured i would but a ssr or hytech header and just install the inserts
Old Sep 23, 2008 | 01:57 PM
firemanG's Avatar
Default Re: (DC2 Maggio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Maggio &raquo;</TD></TR><TR><TD CLASS="quote">How hard are the esmm to install. i have this same question. i figured i would but a ssr or hytech header and just install the inserts</TD></TR></TABLE>
I heard esmm is harder to install esp at the subframe. The motormount job isn't that bad cuz all you have to do is swap it. Do a search on clubrsx. You will find instructions on how to install both and better info about them than around here
Old Sep 23, 2008 | 04:45 PM
DC5 Maggio's Avatar
Default Re: (firemanG)
thanks man
glowponie
Jul 24, 2016 10:10 AM
gosu08
Feb 6, 2010 04:50 PM
kobeballer96
11
Feb 20, 2009 02:21 PM
rogue420
Feb 13, 2009 08:22 AM
dakobester
Aug 1, 2007 06:10 PM
