burning oil
Old Sep 22, 2008 | 08:29 PM
z395civic's Avatar
Default burning oil
i have noticed that my 98 lx burns a good ammount of oil. the thing is that in my old civic i could smell the burnt oil but in the accord i cant smell it nor can i see any blue smoke comming out of the exaust, i just find the black burnt oil "dust" all over my bumper. it only has 114000 miles on it and i got it from a 40 year old woman so im assuming she didint beat on the car. did a compression test and was around 180 for all cylinder so it cant be the rings right? any idea on what it could be? also herd that if your car burns oil and you run full synthetic it wont burn any or little to none oil? any truth to this?
sry for the long post
Old Sep 22, 2008 | 11:44 PM
johnlear's Avatar
Banned
That's a short post!
Have you any oil leaks? "Black dust" sounds more like a symptom of running rich than burning oil.
If you are burning oil then it can come from either poor oil ring sealing or from worn valve guides / valve stems, or valve guide seals...
Old Sep 23, 2008 | 05:32 AM
z395civic's Avatar
Default Re: (johnlear)
i did just put a apexi ws2 exhaust on it. would that cause it to run rich?
Old Sep 24, 2008 | 11:22 AM
z395civic's Avatar
Default Re: (z395civic)
bump
Old Sep 24, 2008 | 03:51 PM
TOO MUCH TORQUE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z395civic &raquo;</TD></TR><TR><TD CLASS="quote">i did just put a apexi ws2 exhaust on it. would that cause it to run rich?</TD></TR></TABLE>
no
check for leaks!
Old Sep 24, 2008 | 05:51 PM
b18cKoupe's Avatar
Default Re: (TOO MUCH TORQUE)
As for the last part of your post about if you change to synthetic it won't burn any oil in my opinion is false. First of all if it's burning oil there is a reason, and I assure you it is not the oil your using. That said I've always been told on higher mileage cars you are much better off with a dino oil as opposesed to synthetic simply because the synth is more "slippery" and more likely to expose any faulty or worn seals or rings on a high mileage car. All 3 of my hondas(d16z6, f22, and b18c) are over 190k except the gsr which is probably around 100k are high mileage and I only run good old 5w-30 with no oil burning issues. My advice is save your money and use dino and find the real leak or if your burning oil check your rings or valve seals.
Old Sep 24, 2008 | 06:13 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: (b18cKoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe &raquo;</TD></TR><TR><TD CLASS="quote">As for the last part of your post about if you change to synthetic it won't burn any oil in my opinion is false. First of all if it's burning oil there is a reason, and I assure you it is not the oil your using. That said I've always been told on higher mileage cars you are much better off with a dino oil as opposesed to synthetic simply because the synth is more "slippery" and more likely to expose any faulty or worn seals or rings on a high mileage car. All 3 of my hondas(d16z6, f22, and b18c) are over 190k except the gsr which is probably around 100k are high mileage and I only run good old 5w-30 with no oil burning issues. My advice is save your money and use dino and find the real leak or if your burning oil check your rings or valve seals.</TD></TR></TABLE>
This man speaks the truth
I swapped a ZC into my Civic with less than 30K on it. I used 5W30 for one oil change. Before 1K miles were over I had burned 1qt, switched back to Mobil 1 and it never burned again.
Old Sep 24, 2008 | 07:25 PM
z395civic's Avatar
Default Re: (Ross 2.0)
thanks guys. one of my buddies works for a honda shop, ill have hiim check the valves and seals for me. if it is running ritch though what would cause that? will something as simple as changing my plugs and wires fix it?
Old Sep 24, 2008 | 08:31 PM
JasonHi's Avatar
ist it kinda bad to switch from synthetic to regular being that synthetic is positive and regular is neg + positive? not really sure. thats what i heard a long time ago.
Hans5849
Jun 10, 2005 05:24 AM
Jeff
Apr 18, 2005 06:23 AM
peel17
Feb 1, 2005 11:28 AM
CroSi
Aug 14, 2003 04:32 PM
Pinpid
Dec 17, 2002 04:55 PM
