92 accord no fire or fuel any suggestions
92 4 door auto, my friends accord, started cuttin out when he got on it, and then just died one day and wont start, i checked timing..good checked fuel pressure..none fuel pump doesnt prime, tested coil..bad im thinking maybe the control module because he said he bought a new coil about 5 months ago, doesnt the control module have something to do with the fuel cutoff relay on these cars....main relay is good, just thought it was weird coil tested bad and fuel pump is not priming, the starter does come on so i dont think it could be the ignition switch, any suggestions?
i know how to test it.........something is causing fuel and fire problem together...unlikely 2 diff things went bad at same time
im thinking the icm is the problem, havent got it to autozone yet to test it but im thinking the reason the coil tested bad and the fuel pump wont come on is the icm, does that make sense, because i think there is a fuel cut off relay that is on the same circuit as the icm....keep the suggestions coming
Roger Denton
Apr 15, 2019 05:53 AM
accordexdude25
Nov 9, 2012 12:01 PM
