TW: Complete SEMI BUILT GSR SWAP 2700obo
NEW PRICE 2200
I got a complete GSR Swap for sale. Bought the long block off of gsp ej1-em1. Will come with everything to drop into your car. This is the most complete swap you can get it is ready to drop into any car. Will come with harness, motor, tranny ecu, mounts, axles EVERYTHING!!!Motor is currently still in the car if your interested you can come by and test drive it but you must have cash in hand no free test rides.
BLOCK
stock obdI 95 b18c1
00 oil pump and crank position sensor installed
Got it with with 110k on it put a lil under 10k since ive had the motor
Greddy 4-2-1 headers carb legal
Oiled changed every 3k miles with castrol full synthetic
HEAD
2000 GSR head 0 mile when i got it put under 10k on it
Portflow valvetrain
Bronze valve guide
Blox Type B Cams
Blox Cam Gears
Blox Intake manifold
STR Fuel Rail
B&M fuel pressure regulator
DRIVETRAIN
2000 GSR tranny shifts smooth no pop outs or grinds
6 puck unsprung copper/carbon clutch from redzone
Stock gsr flywheel
P28 ECU tuned by redzone made 168hp and 123 torque with greddy headers and the radiator blew on the dyno. Im pretty sure you could make more if you had better headers.
Mounts are stock mounts that are welded solid
BAD
Burns a little oil but what vtec motor doesnt and its leaks a bit of oil from the head on the vtec solenoid side i heard it was normal but if your concerned you can just change out the headgasket.
2200obo
Will have pics up soon need to get my camera back.
Modified by t0mmysays at 3:01 PM 9/24/2008
Modified by t0mmysays at 9:18 PM 9/25/2008
Modified by t0mmysays at 9:19 PM 9/25/2008
Modified by t0mmysays at 11:40 AM 9/30/2008
BLOCK
stock obdI 95 b18c1
HEAD
Portflow valvetrain
Bronze valve guide
Blox Type B Cams
Blox Cam Gears
STR Fuel Rail
DRIVETRAIN
Stock gsr flywheel
BAD
2200obo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Risa »</TD></TR><TR><TD CLASS="quote">bumpage</TD></TR></TABLE>
thanks for the bump
thanks for the bump
Chizle707
Northern California (Sales)
Sep 2, 2008 10:18 PM
Schister66
Aug 30, 2006 10:03 AM
