y8 motor in 91 crx.....mount question
ok i got my y8 motor in my rex... well right now front and rear mounts are holding it in
this my problem... the bracket that is bolted to the side of the block (driver side) and so i went to bolt on the mount on and the holes were like few mm to wide...
so my question is what mount are u guys using on the driver side to bolt up?
the mount that came off the 99 civic i had? and u talkn bout that brace that looks like a trangle with 3 holes ? right
No, you will need to pick up the mount off of a D15/16 out of an EF. Local junkyard should have them all over the place.
Just did this a few days ago for mine. You will also need to trim the timing belt cover a tiny bit to make it fit.
like the guy above said you need the bracket that mount to the block and a motor mount for a 88-91 crx or civic
charlie_sohc
Apr 25, 2009 09:31 PM
blacksol95
Jul 3, 2004 11:42 AM
Tw1n Turb0 Z
12
Jun 19, 2004 09:39 AM
