please help me Integra bogging misfireing please help me out
Old Sep 22, 2008 | 05:16 PM
slowej1's Avatar
Default please help me Integra bogging misfireing please help me out
I have a 1997 integra ls that is bogging. The problem came about after i changed the head on the car because one of the spark plug holes was cross threaded. After we replaced the head we adjusted the valves. Due to a jackass friend of mine my distributor fried because he pulled out all the cables wail the car was idling. So the distributor was replaced to. The car use to run perfect before the replacing of the head.
I would be driving the car normally and the car will loose power misfire and even back fire at times. The crazy part is that it doesn't do it all the time. I have check the distributor and that's fine. I changed the spark plugs, wires, cap, and rotor still nothing. The car is not giving me a check engine light. I have even check the cars timing to see if that could be the problem but everything that i have tired has failed and the car is still doing the same thing. What can it be any help is appreciate. I took the car to a local shop and they cant even figure it out.
Old Sep 22, 2008 | 05:28 PM
danthemang3's Avatar
Default Re: please help me Integra bogging misfireing please help me out (slowej1)
what brand of spark plugs, wires, cap and rotor are you running?
Old Sep 22, 2008 | 05:31 PM
slowej1's Avatar
i know the spark plugs are nrgs that i got from auto zone and the other stuff is all from autozone too but when ever i do tune ups on my cars i use autozone part and i never had a problem
Old Sep 22, 2008 | 05:34 PM
Default Re: (slowej1)
not to knock you but some people get lucky most don't and it seem like you didn't this time. this is the easiest place to start i have seen some nasty things happen with aftermarket parts. get ngk's from autozone. cap, rotor, and wires from acura or at least some ngk wires.
Old Sep 22, 2008 | 07:32 PM
slowej1's Avatar
ok but witch nrgs spark plugs becasue i have some rite now but they are like the cheapest
Old Sep 23, 2008 | 06:57 AM
slowej1's Avatar
sorry i mean that i have ngk spark plugs but the are the cheap ones
Old Sep 23, 2008 | 06:58 AM
the cheap ones are fine actually best. but with the cap and rotor i have seen cars stop running 30 seconds down the road with that aftermarket crap.
Old Sep 23, 2008 | 07:01 AM
slowej1's Avatar
but i have tried other distributers on my car and it still does the some thing
Old Sep 23, 2008 | 09:53 AM
check your tps sensor and wiring. try wiggling the wires and see if the motor acts up. could also be your map sensor.
Old Sep 23, 2008 | 10:28 AM
evildc2's Avatar
How its your idle ????
you said you put a different head..........are you sure the head is good ??
it could also be a cracked injector or loose timing belt.
Old Sep 23, 2008 | 06:12 PM
slowej1's Avatar
The idle sometimes it drops down to like 200rpm and the car shakes like its misfireing. About the timing belt im going to check that and how can the head be bad if the car runs normal sometimes or when im crusing like at 60mph plus. When i get out of the highway it does it alot too.
Old Sep 23, 2008 | 08:11 PM
frost_0ne's Avatar
maybe ur valves are bent?
Old Sep 24, 2008 | 07:38 PM
slowej1's Avatar
ok any other possibility im going to check everything out
Old Sep 24, 2008 | 09:25 PM
Steven.'s Avatar
Did you connect the Spark plug wires in the correct fire order.
Old Sep 25, 2008 | 07:26 PM
slowej1's Avatar
yeah my fireing order is rite. I think its the tps im going to the local junk yard tomorrow to get a tps and im going to try that because i notices that when the car starts to bog and i put the gas all the way down it goes away.
Amanduhhh
Mar 1, 2011 07:05 PM
miguey310
Jun 2, 2009 12:29 AM
DIS-1
12
Jun 20, 2007 01:40 PM
mR. Vash
Sep 8, 2004 10:50 AM
unLuckylude666
Apr 17, 2004 09:41 AM
