Tail Lights very dim..
Old Sep 22, 2008 | 04:51 PM
R81_DC2's Avatar
Default Tail Lights very dim..
So i put some 98 tails on my car a while back and i changed my bulbs and everything brand new but for some reason when i press on the brakes the tail light brakes are BARELY visible. i'm not sure what the problem could be? ive checked the wiring and these bulbs are only a month old i don't see why the bulbs would be the problem.
Old Sep 22, 2008 | 05:12 PM
danthemang3's Avatar
Default Re: Tail Lights very dim.. (R81_DC2)
bad ground
Old Sep 22, 2008 | 05:37 PM
R81_DC2's Avatar
Default Re: Tail Lights very dim.. (danthemang3)
how can i fix that?
Old Sep 22, 2008 | 05:40 PM
i know you said you checked the wiring. but ever since working in a shop for the last 4 years that is the only problem i have seen cause that. so go over all of your ground wires. check for loose connections, broken wires, grounds bolted onto paint and not clean metal. good luck
Old Sep 23, 2008 | 08:35 AM
speedtech_7gc's Avatar
get some led bulbs. super brighter.
Old Sep 23, 2008 | 08:40 AM
superacecardriver's Avatar
check the sockets for anything wrong. I know this is acura, in which I do own a Integra. The socket on my crx was the cause for a dim Right side brake light.
devious
Aug 5, 2020 03:45 PM
theseeker4
Nov 4, 2015 12:11 AM
andyisftw
May 14, 2010 10:55 AM
BG-Teg
May 13, 2007 07:54 PM
hi mom
Aug 19, 2005 12:39 PM
