O2 sensor reading? MPG related
Old Sep 22, 2008 | 04:49 PM
ruffrhyder's Avatar
Default O2 sensor reading? MPG related
So my 97 GSR has been getting worse gas mileage than compared to a few months ago. I normally got about 31-33 mpg. Then I noticed, it dropped down to only 26-28 mpg. Same commute, same driving habits, etc. I doubt the gas stations around here switched to the winter mix that has more ethanol or whatever, cause it is still hot here, and MPG went down towards the end of summer.
So I did a complete tune up, check out tire pressures, etc. MPG is still the same.
So I'm thinking the stock O2 sensor may be getting old. The voltage bunces form only .075 volts to .785 volts in closed loop.
I belive the manual says the voltage should bounce from .1-1 volts. Does a lower voltage reading mean a lean or rich mixture, and will that be the cause of the drop in MPG?
Old Sep 22, 2008 | 05:37 PM
BoSox46GSr's Avatar
Default Re: O2 sensor reading? MPG related (ruffrhyder)
Well I would say that would be your cause for worse gas mileage. How many miles are on the O2? I'd say swap it out, and you should see a fairly decent change in MPG.
Old Sep 22, 2008 | 05:42 PM
ruffrhyder's Avatar
Default Re: O2 sensor reading? MPG related (BoSox46GSr)
92k miles, any idea what the low voltage indicates? Lean or rich mixture?
Old Sep 23, 2008 | 08:08 AM
moufue's Avatar
.1=lean, 1v=rich. your o2 sensor should constantly go up and down from typically .1 -1 to maintain 14.7 to 1 A/F ratio. u can see this on a scan tool or voltmeter
Old Sep 23, 2008 | 08:15 AM
moufue's Avatar
sorry missed that u had a voltage reading. I would replace the sensor
mikeSONICGSR
Jan 21, 2009 05:47 PM
ruffrhyder
Engine Management and Tuning
Sep 25, 2008 07:56 PM
jentee
Jun 8, 2008 11:01 PM
b18LS
Jul 23, 2007 10:14 PM
plz turn off trial user
19
Jun 10, 2006 11:18 AM
