wheel hop really bad
Old Sep 22, 2008 | 03:57 PM
kings**t's Avatar
Default wheel hop really bad
ok i have a really bad problem! my 97 teg hops really really bad when i turn the corner and press the gas but if i coast and turn it does not hop and yes it does it turning both ways? i have carbon fiber axles and dont know why it is doing this it sounds like a half shaft but they look and fell fine?
trans:jdm b16 lsd
motor:gsr fully built
axels:carbon fiber
any help will help thanks
ps: i checked the motor mounts and two are enjo motor mounts and the rear is stock if it matters,
o ya and if i press the gas going straight down the road it pulls to the right?
Old Sep 22, 2008 | 06:19 PM
D-Atk's Avatar
what condition are the tires in?
Old Sep 22, 2008 | 06:49 PM
kings**t's Avatar
Default Re: (D-Atk)
good not new but good
Old Sep 22, 2008 | 07:39 PM
gonmaro's Avatar
Default Re: (kings**t)
did you ever check if your LSD is still working? I've seen times where the clutches slip and make the car shutter. And with your torque steer, that might be your problem. Check you struts as well
Old Sep 23, 2008 | 05:00 PM
kings**t's Avatar
Default Re: (gonmaro)
how do i check if the lsd is still working? and my susp is all brand new omin coilover setup.
Old Sep 23, 2008 | 05:57 PM
The G2 Racer's Avatar
Jack the car up, turn the wheels, if both turn the same way then your LSD is working.
Could be many things, tires, bad suspension components, etc.
Old Sep 24, 2008 | 03:39 AM
kings**t's Avatar
Default Re: (The G2 Racer)
what kind of bad susp comp? and also would my z10 traction bar be a problem? if they are not set right?
Old Sep 24, 2008 | 04:51 AM
Possibly.
Bad springs, shocks/struts.
What tires are on the car?
Old Sep 24, 2008 | 06:15 AM
deftonerider's Avatar
low con arm bushings rimarily the back one or maybe upgrade to o single piece low con arm
Old Sep 24, 2008 | 07:04 AM
evildc2's Avatar
Default Re: wheel hop really bad (kings**t)
check your wheel alignment, it could be off.
Old Sep 29, 2008 | 02:42 PM
kings**t's Avatar
Default Re: wheel hop really bad (evildc2)
nope but check this out and tell me what you guys think plez?
https://honda-tech.com/zerothread?id=2396287
Old Sep 29, 2008 | 05:58 PM
gonmaro's Avatar
did you ever check to see if the LSD was working?
try changing the fluid and go do some figure "8"s for a while
CW_97_ITR
Nov 8, 2004 03:34 PM
TmeX05
Jan 14, 2003 07:59 PM
ROCcityRSX_S
Dec 5, 2002 07:29 PM
Ef Whore
Nov 15, 2002 11:51 AM
celica73
33
Aug 21, 2002 10:33 AM
